Bill Schlatterer
Posted: Fri Feb 10, 2006 6:21 pm Post subject: Changing Picture Size Was: Toggle Switch Breakers |
Bob, lot of ways but the easiest is to let your email software handle it. I use Outlook 2003 and anytime you attach a picture, it gives you an option to cut them to small, medium, or large resolution for email purposes. When I send a 1meg jpg file using the large setting for clarity, it comes through at about 300kb. On small, it will take it way down maybe less than 50k. For most purposes, the small setting works fine.
Bill S
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of NYTerminat(at)aol.com
Sent: Friday, February 10, 2006 7:41 PM
Subject: Re: RV10-List: Toggle Switch Breakers
Michael
Thnks for lookinging out for us dial-up guys. By the way how do you change a 1 MB picture into a 50k picture?
NYTerminat(at)aol.com Guest
Posted: Fri Feb 10, 2006 8:22 pm Post subject: Changing Picture Size Was: Toggle Switch Breakers |
Bill,
Thanks for the lesson, I am using AOL and don't see that option.
In a message dated 2/10/2006 9:23:02 PM Eastern Standard Time, billschlatterer(at)sbcglobal.net writes:
| Quote: | Bob, lot of ways but the easiest is to let your email software handle it. I use Outlook 2003 and anytime you attach a picture, it gives you an option to cut them to small, medium, or large resolution for email purposes. When I send a 1meg jpg file using the large setting for clarity, it comes through at about 300kb. On small, it will take it way down maybe less than 50k. For most purposes, the small setting works fine.
