frank.phyllis(at)mindspri Guest
Posted: Wed May 30, 2007 10:28 am Post subject: Break thread sealant |
All
What sealant (and source) works well for the brass fitting that screws into the brake cylinders, connects the brake fluid line to the cylinder? I have a leak and think maybe a different sealant might do the trick.
Frank
N5929
Series 7
rdmac(at)swbell.net Guest
Posted: Wed May 30, 2007 1:58 pm Post subject: Break thread sealant |
Teflon tape worked well for me.
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of frank.phyllis(at)mindspring.com
Sent: Wednesday, May 30, 2007 1:28 PM
Subject: Break thread sealant
All
Frank
N5929
Series 7 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234
cathyboone(at)softcom.net Guest
Posted: Wed May 30, 2007 3:31 pm Post subject: Break thread sealant |
Frank,
I used Permatex Pneumatic/Hydraulic Sealant PX #54540. Teflon tape is not recommended in aviation application and be advised there are two types of teflon tape. If you must use it, at least use the one for petroleum application.
Larry Boone, Denair, CA
Building Series 5 Outback
Rotax 912 uls, IVOPROP Med
Guy Buchanan
Posted: Wed May 30, 2007 7:58 pm Post subject: Break thread sealant |
At 11:27 AM 5/30/2007, you wrote:
| Quote: | | What sealant (and source) works well for the brass fitting that screws into the brake cylinders, connects the brake fluid line to the cylinder? |
I recommend Permatex liquid thread sealer sold at most auto parts stores in a little white tube.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
kitfoxpilot(at)msn.com Guest
Posted: Fri Jun 01, 2007 7:01 pm Post subject: Break thread sealant |
Loctite 567, Matco uses this and so do I.
| Quote: | From: Guy Buchanan <bnn(at)nethere.com>
Subject: Re: Break thread sealant
Date: Wed, 30 May 2007 20:55:51 -0700
Guy Buchanan
San Diego, CA
Don’t miss your chance to WIN $10,000 and other great prizes from Microsoft
