Ed Anderson
Posted: Sat Jun 02, 2007 11:39 am Post subject: Fit of Tip Up Canopy Seal |
I received the Tip Up seal from Peter Hunt, yesterday. Took it out and test fitted it to my RV-6A Tip Up today.
The seal looks like it will work just fine for the Tip Up. Its has a "C" section squeezed down (metal C clamp inside the rubber) so it will firmly slip and clamp over the metal strip just below the perimeter of the canopy forward bulkhead - the one in front of the instrument panel. There is a round "bulb" seal on top of the "C" section which the closed canopy skin will seat on and depress slightly to form a seal.
I am going to order 5 feet for my RV-6A - at $25 hard to beat. My current kluged up seal using two separate seals will eventually stop being effective.
I still have the segment of seal I was sent if anyone else around here (Charlotte,NC) would like to test fit. However, if you do not have your Tip-Up canopy installed - a fitting probably won't tell you much.
It appears that the only critical thing is that you located the metal lip correctly along the bulkhead - if too low, the forward canopy skin would probably not come down on the seal sufficient to compress it. If too high - well, you have other problems - like closing the canopy {:>)
Here is Pete's description of his seal in case mine was unclear: My "C" shaped gasket just slides over the rear edge of this joggle. What makes my seal work is this. Running along the top of my "C" shaped seal is a tiny round flexible tube. The glareshield of the canopy extends forward of the plexiglass (outside) about 5 inches and this forward edge closes into/over the joggle. The tiny round tube running along the top of my "C" seal makes contact with the canopy under the front edge of the canopy when it is closed. Nothing is visible. Just remove Van's seal from on top of the joggle and slide mine onto the rear edge of the joggle. No adhesive needed
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.dmack.net/mazda/index.html
Ed Anderson
Matthews, NC
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
Steve Glasgow
Posted: Sat Jun 02, 2007 12:29 pm Post subject: Fit of Tip Up Canopy Seal |
Ed, Cappy will take the sample of the seal. Can you give it to Bill C and I will get it from him.
_________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
Ed Anderson
Posted: Sat Jun 02, 2007 3:21 pm Post subject: Fit of Tip Up Canopy Seal |
Ok, Cappy. Next time I see Bill, I'll give him the snip of seal I got.
Ed
Matthews, NC
N8391Mike(at)aol.com Guest
Posted: Sun Jun 10, 2007 8:26 am Post subject: Fit of Tip Up Canopy Seal |
what is the info to contact Peter Hunt to order the seals for the tip up.
Andre Robert
RV6 tip up.
See what's free at AOL.com.
Ed Anderson
Posted: Sun Jun 10, 2007 10:02 am Post subject: Fit of Tip Up Canopy Seal |
Hi Andre,
Pete Hunt is offering the seal for $5.00/foot or $25 for the five feet needed. I've order one.
Also he has a neat storage kit for the back of the seat.
Here is Pete's e mail: PeterHunt1(at)aol.com (PeterHunt1(at)aol.com)
Here is his mail address
Pete Hunt
849 Harbor Island
Clearwater, FL 33767
727-447-6409
Ed
Ed Anderson
Matthews, NC
Matthews, NC
