aprazer
Posted: Wed Jun 13, 2007 8:05 am Post subject: Vent cuttingVent cutting |
OK, I give up! What is a flycutter tool and how is it used?
Mack
_________________ The poh-oh-unemployed farm boy from Idaho |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Wed Jun 13, 2007 8:34 am Post subject: Re: Vent cuttingVent cutting |
Something like this http://www.aircraftspruce.com/catalog/topages/holecutter.php
I prefer the type that doesn't use the drill bit - it simply has a center shaft the same size from end to end. You have to drill the pilot hole first and then use the fly cutter. With thick stuff and a drill press you can turn it under power otherwise the best approach is to turn it by hand and score the material. In the attached picture I made a inspection hole by:
1.) Scoring the metal by hand with the fly cutter. This is in the leading edge skin.
2.) Using an OLFA knife (see www.601.org) to score a line connecting the edges of the two circles.
3.) Used a step drill to enlarge one of the pilot holes large enough to insert a nibbler tool which I used to split one end enough that I could get my pliers on a scored edge and...
4.) Carefully worked my way around the hole, separating the the pieces I wanted to remove.
There.... that's more of an answer than you probably wanted
Description: |
Removing metal that was scored with a hole cutter. |
Filesize: |
45.69 KB |
Viewed: |
398 Time(s) |
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Wed Jun 13, 2007 10:25 am Post subject: Vent cuttingVent cutting |
Hi Mack,
The type we're usually talking about on this forum is a short 3/4-inch
body with a stem on one end for a drill chuck,
a hole for a 1/4-inch drill at the other with two Allen screws to hold
the drill and in the middle a square hole that allows
a beam to pass thru, be adjusted and secured with another Allen screw.
At the end of the beam, a square hole
parallel with the drill is made for an 1/8th inch tool bit that's ground
from the inside edge to obtain a hole with a
straight edge. The drill can be used to power it, but for lightening
holes in the wings or fuselage, I prefer to pre-drill
the center hole and then turn the fly-cutter by hand very slowly with
light pressure to cut a hole somewhat like a compass.
In a drill press, you can cut really good holes in an instrument panel
rather quickly. About $12.00 locally.
Mack Kreizenbeck wrote:
Mack
aprazer
Posted: Wed Jun 13, 2007 4:36 pm Post subject: Re: Vent cuttingVent cutting |
Tim and Larry,
Thank you very much for the picture and description. In reading the thread, it appears that this flycutter can be used on the bubble! Micheal Heintz cut a round hole in bubble of the XL prototype, but I forgot to quiz him about his method. Idaho gets extremely hot during the summers and I need additional air.
Thanks again for your help
Mack
Posted: Wed Jun 13, 2007 7:56 pm Post subject: Vent cuttingVent cutting |
Quote: | In reading the thread, it appears that this flycutter can be used on the
bubble!
I think most would agree that it is best to turn a fly cutter by hand if you
can't use it in a drill press. Same goes for cutting holes with it in sheet
aluminum.
-- Craig
