cehoffman(at)bellsouth.ne Guest
Posted: Sat Jun 16, 2007 6:04 am Post subject: Windshield |
What is the proper technique for the bottom edge of the windshield: taper it so that the edge sits flat against the forward fuse or leave it at 90 deg to the windshield surface and let it fill in with fiberglas or filler??
Cal Hoffman
40119 - obviously windshield install
Change the world one loan at a time - visit Kiva.org to find out how
Deems Davis
Posted: Sat Jun 16, 2007 6:25 am Post subject: Windshield |
If you've got some precision machining equipment and skills, flat is
better, elsewise I think you'll end with a combination approach. i.e.
it's best if you can have a mated surface between the windscreen and the
upper fuse. However, for those, like me, who lack the
skills/patience/knowledge... fill in the blank.... it was necessary to
trowel in some flox to fill the voids.
http://deemsrv10.com/album/Sec%2045%20Cabin%20Doors%20and%20Transparancies/slides/DSC04378.html
Deems Davis # 406
Baffling / Plenum / Engine Stuff
Cal Hoffman wrote:
| Quote: | What is the proper technique for the bottom edge of the windshield:
Cal Hoffman
Dave(at)AirCraftersLLC.co Guest
Posted: Sat Jun 16, 2007 8:51 am Post subject: Windshield |
Just get it close to the fuselage. Don't bother tapering it. You can fill it from the outside with micro to get a smooth transition. As long as it's with in 1/8"-1/4" you'll be OK.
After the windshield is roughly fit you might want to mark the outline against the fuse and paint inside. It's going to be hard to get in there later.
I painted the margin about 1.5" around the bottom inside of the windshield with rattlecan flat black before it went in too. Then after the micro squeezed under the plastic a bit, I was able to hide it with flat black applied with a long paintbrush.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Cal Hoffman
Sent: Saturday, June 16, 2007 7:04 AM
To: RV 10 List
Subject: Windshield
Cal Hoffman
