dholly
Posted: Mon Jun 18, 2007 7:50 am Post subject: Are Kitfox I-III and Avid HH ribs interchangeable? |
You, like I, may have heard or read that Kitfox I-III and Avid HH use the same airfoil and wing ribs, therefore, are exact duplicates of each other. Thanks to a local KF-II builder, I had the opportunity to do a hands-on comparison of both ribs. Pics show results.
Note: in photos, KF-II rib is a new replacement which matched original perfectly; Avid HH rib has blue tape on capstrip.
| KF-II rib (top) and Avid HH rib (lower) |
471.54 KB |
408 Time(s) |
| Undercamber difference is quite measureable. |
433.78 KB |
393 Time(s) |
| Lower curve of Avid HH incorporates more undercamber. |
353.01 KB |
401 Time(s) |
| Top curves the same, KF-II rib slightly wider. |
357.84 KB |
390 Time(s) |
