franicaza(at)yahoo.com.mx Guest
Posted: Mon Jun 18, 2007 1:04 pm Post subject: Nose wheel and weight & balance for Classic IV |
List,
I have converted my classic IV into a nose wheel. I´ve
flown it twice and it has been quite difficult to make
the flair before main wheels touch the ground(Grove
landing gear).
Just two questions:
1. Has someone noticed that after makeing the nose
wheel conversion?
2. Where can I get the plot to calculate Weight &
balance? My manual has just the tail dragger option.
Thanks in advance,
Francisco Icaza
Classic IV Rotax 912-S
Mexico City.
___________________________________________________________
La mejor conexión a Internet y <b >2GB</b> extra a tu correo por $100 al mes. http://net.yahoo.com.mx
wingnut
Posted: Mon Jun 18, 2007 3:16 pm Post subject: Re: Nose wheel and weight & balance for Classic IV |
What makes you think the W&B plots would be different for tail dragger vs tri gear? The plane doesn't know the difference when it's in the air right?
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Jun 18, 2007 4:31 pm Post subject: Nose wheel and weight & balance for Classic IV |
Luis,
Actually, I think the airplane would know the difference. a big bunch of
weight in the nose gear under the engine, no tail wheel eleven feet back and
the aft positioned maingear would definitely alter the CG - nice to know
where it actually is and and if it is still in the envelope. From the post,
it sounds like it has moved forward a bit.
I think he is asking if anyone has the arm lengths for the aft positioned
landing gear and the new nose wheel out front for the re-weighing
calculations and the form for plugging in all the numbers.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 870 hrs.
Float Flyr
Posted: Mon Jun 18, 2007 4:38 pm Post subject: Nose wheel and weight & balance for Classic IV |
Icaza:
Re-weigh the plane.
The arm for the datum to the nosewheel will be considered negative. After that the calculations are pretty similar to the conventional gear.
E.g.
Weight dist arm
Nose wheel 100lb. (at) -30" = - 3000in lb
Left main 275lb. (at) 20" = 5500in. lb.
Right main 280lb (at) 20" = 5600in. lb.
Weight 655lb. (at) 5600 + 5500 - 3000 = 8100inlb
8100in.lb./655lb. = 12.36"
In this example the CG is 12.36" aft of the datum
The figures I used in this example do not reflect the weighed values of any particular aircraft. I pulled them and the distances from the datum out of thin air.
[img]cid:742343600(at)19062007-1B51[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
509 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Mon Jun 18, 2007 4:51 pm Post subject: Nose wheel and weight & balance for Classic IV |
The arms of both the mains and the nose over the tail have moved.... You better believe the CG is moved. Also consider the weight of the nose gear as opposed to the tail wheel. Once the CG is calculated the corrections for loading/fuel will be exactly as before. CG is one of the important changes when ever you change gear configuration.
[img]cid:057024900(at)19062007-1B58[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
486 Time(s) |
Kitfox III-A
Float Flyr
Posted: Mon Jun 18, 2007 4:58 pm Post subject: Nose wheel and weight & balance for Classic IV |
Lowell:
I think the datum on my plane is the leading edge of the wing. All he needs t0o do is drop a plumb bob from there ands measure the linear distance to the nose wheel and then back to the mains. He should re-weigh the plane.
[img]cid:054185600(at)19062007-1B5F[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
454 Time(s) |
Kitfox III-A
wingnut
Posted: Mon Jun 18, 2007 5:34 pm Post subject: Re: Nose wheel and weight & balance for Classic IV |
Quote: | Actually, I think the airplane would know the difference. a big bunch of
calculations and the form for plugging in all the numbers. |
That's not what I meant. In the original post, Francisco mentioned that he has the manual which has W&B procedures for the tail dragger configuration. I'm just pointing out that the same manual applys for the nose wheel configuration. Of course, his balance has changed. In fact, given his inability to flair on landing, I'd say he's flying very nose heavy. But the aerodynamics haven't changed so same procedures apply and the datum plane hasn't moved.
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Posted: Mon Jun 18, 2007 6:31 pm Post subject: Nose wheel and weight & balance for Classic IV |
Luis,
My concern is that I moved several weights that
obviously could change the balance of my plane during
flight. I changed the front welded main gear for the
heavier Grove landing gear, now in the aft position.
As well the nose gear is much more heavier than the
tail wheel (but much closer to the C.G.), and so on. I
also suppose that it was calculated by SkyStar and by
Kitfox Aircraft. I just want to know how I can
calculate weight & balance again with that
configuration. It´s as well mandatory for DGAC
(Mexican FAA) for anyone that made those changes.
Francisco Icaza.
Mexico City.
right?
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=119241#119241
Llama gratis a cualquier PC del mundo.
Con una excelente calidad de sonido.
http://mx.messenger.yahoo.com/
wingnut
Posted: Mon Jun 18, 2007 7:20 pm Post subject: Re: Nose wheel and weight & balance for Classic IV |
flight. |
Yes, the weights have moved. The procedure to find your new center of gravity is the same. You stick a scale under each wheel, and multiply the weight at each with its distance from the leading edge of the main wing (as Noel pointed out, the distance is negative for the nose gear). There's even an example in the manual. The only difference for you is that all the distances have changed but you just have to measure it like Noel suggested. You can even use the same chart showing the CG limits at different take off weights.
I wouldn't fly the airplane until this is sorted out one way or the other. You're probably way past the forward cg limit right now.
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Float Flyr
Posted: Tue Jun 19, 2007 5:00 am Post subject: Nose wheel and weight & balance for Classic IV |
You're spot-on Luis. My misunderstanding of your comments.
The only difference is the arm for the nose wheel will be negative ( datum between the nose and mains). You are also correct in saying the plane won't really care as long as the CG is within limits.
If there is a problem with the plane flying straight an level it may be best to have a heart to heart with it and it should be told in the strongest terms to, "Fly right!"
[img]cid:625354612(at)19062007-2C83[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
445 Time(s) |
Kitfox III-A
kitfoxmike
Posted: Tue Jun 19, 2007 5:46 am Post subject: Re: Nose wheel and weight & balance for Classic IV |
I am surprised that you actually flew the plan without reduing the weight and balance. Now with that said, I agree, you need to do the math. And to make sure you have it right and you believe you found the center of gravity, take and jack the plane off the wheels at the point you believe the CG is at. The plane better balance, not drop at the front or back. My feeling is you are too nose heavy, and until you get some weight shifted to the rear, you will not be able to properly flair to land. Good luck and fly safe. Of course the jacking and double checking the CG is optional, so is doing a check of the engine and airframe before flight. After all, you are only above ground when flying, and It's not too far down to the ground, or is it???
Float Flyr
Posted: Tue Jun 19, 2007 7:27 am Post subject: Nose wheel and weight & balance for Classic IV |
Mike:
They say you should learn something new everyday. Today is definitely no exception.
You referred to jacking a plane up at the suspected CG... This sounds useful if you can tell me how. There are no hard points on my plane any where near the CG. Lifting by the chines probably won't work either because the CG will be above the jacking point and won't balance there either.
We used to lift float planes off the dolly in the hangar using an overhead crane and a special spreader bar which attached to either the wing attach points or specially installed lifting rings. I always found it was easier to lift if I calculated the CG before starting the lift. of course when you took the plane off the floats the CG changed dramatically but with the use of a couple of guy ropes I was able to single handed change from flats to wheels.... going the other way (installing floats) required more help and a dictionary of four letter words!
The last two times I put my 'Fox on floats I lifted it from the rafters in the garage using three points and three small block and tackle. Using that set up knowing the CG before starting wouldn't have helped at all.
The only way I can see to find the CG is by mathematical calculation... Level the plane, weigh the muggly ugger and jump head first into the math. If you think you've messed up get someone to check your measurements and/or math... I'm sure there are enough people who would be happy to do that.
[img]cid:972410615(at)19062007-2C8A[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
494 Time(s) |
Kitfox III-A
kitfoxmike
Posted: Tue Jun 19, 2007 9:07 am Post subject: Re: Nose wheel and weight & balance for Classic IV |
Not having done this on a fox, here is an example of trying. Take the doors off and run a strap through the fuse and out to the tips and the up to a lift in the rafters, since the cg would more than likely be in that area, I think generally 12 inches back from the front of the wing, but just guessing right now, need to check the paper work in my plane. I suppose you could lift right at the rib at the tips. I've lifted one side for installing a scale in this location when putting the scale under the wheel when I did weight and balance.
I build RC airplanes and fly them, been doing this since 1991. I found it pretty convenient to have a span from the factory where the cg was and made sure that the model balanced before flying them and this is how we did it, lift at the cg. On the nose wheel planes I would put the cg as far back(tail heavy) as I could and then when landing I would hold the nose off the ground all the way back to the pits. Really impressed a lot of people. After all most never made the runway, they ended up in the grass, and here I was landing on center line and taxi with the front wheel off the ground.
klschooley(at)hotmail.com Guest
Posted: Tue Jun 19, 2007 9:30 am Post subject: Nose wheel and weight & balance for Classic IV |
A few things to remember, a new weight and balance is easy to compute, safe
flying (and landing) require a balanced aircraft, and the FAA requires a
current weight and balance to be aboard the acft.
Happy and safe flying, Ken
Quote: | From: "kitfoxmike" <customtrans(at)qwest.net>
Subject: Re: Nose wheel and weight & balance for Classic IV
Date: Tue, 19 Jun 2007 06:46:19 -0700
or is it???
kitfoxmike
model IV, 1200
speedster
912ul
building
RV7a
slowbuild wings, fuse, finish kit
"if you're not getting razzed from pilots or the FAA then you're not
flying enough"
http://forums.matronics.com/viewtopic.php?p=119370#119370
Don’t miss your chance to WIN $10,000 and other great prizes from Microsoft
josandt(at)verizon.net Guest
Posted: Tue Jun 19, 2007 11:43 am Post subject: Nose wheel and weight & balance for Classic IV |
I'm going to show my ignorance here. Since the wheels are always located a set distance fore and aft, why can't one simply calculate weight and balance by examining relative weights on the wheels? Why can't you just put scales under all the wheels, then say nose wheel weight must not exceed a certain percentage of total weight to remain inside CG envelope? I know I'm probably missing something here (this being my first build), but what is it?
John Sandt / KF7 / Trigear / Corvair / BRS / Ridgecrest, CA (land of fruits and nuts)
<<Subject: RE: Re: Nose wheel and weight & balance for <<Classic IV<<The only way I can see to find the CG is by mathematical <<calculation... Level the plane, weigh the muggly ugger and jump <<head first into the math.ÂÂ
propellerdesign(at)tele2. Guest
Posted: Tue Jun 19, 2007 12:12 pm Post subject: Nose wheel and weight & balance for Classic IV |
Sure you can do it this way, (this is the normal way)
just make sure that the plane is in the correct angle it should be weighted.
Jan
wingnut
Posted: Tue Jun 19, 2007 12:18 pm Post subject: Re: Nose wheel and weight & balance for Classic IV |
Quote: | I'm going to show my ignorance here. Since the wheels are always located a set distance fore and aft, why can't one simply calculate weight and balance by examining relative weights on the wheels? Why can't you just put scales under all the wheels, then say nose wheel weight must not exceed a certain percentage of total weight to remain inside CG envelope? I know I'm probably missing something here (this being my first build), but what is it? |
How do you figure out that percentage? Also, are you going to drive the kitfox up on scales every time your take off weight changes or a passenger brings some luggage? If you follow the procedure detailed in the manual (and summerised by Noel earlier) then you can figure any changes to your CG with just a little math. It's really very easy.
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Posted: Tue Jun 19, 2007 1:00 pm Post subject: Nose wheel and weight & balance for Classic IV |
Weight on front wheel divided by total vehicle weight is a VERY simple fraction that even a small child can do. It's only one operation on a simple calculator (something even I can do!). And since ALL Kitfoxes of the same model should share these weight proportions, it would be very easy for comparison. I'm not suggesting that formal weight and balance should be shortcut, only that it might be a very simple matter to determine what part of the envelope one was operating in (no slide rule and measuring tape required). No slings, jacks, fulcrums, nuclear reactors, or atom smashers. Is it actually "the normal method" as another kitfox lister has said?
John Sandt/KF7/Tri/BRS/Corvair/Ridgecrest,CA
Date: 2007/06/19 Tue PM 03:18:24 CDT
How do you figure out that percentage? Also, are you going to drive the kitfox up on scales every time your take off weight changes? If you follow the procedure detailed in the manual (and summerised by Noel earlier) then you can figure any changes to your CG with just a little math. It's really very easy.
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=119491#119491
Tom Jones
Posted: Tue Jun 19, 2007 1:37 pm Post subject: Re: Nose wheel and weight & balance for Classic IV |
Francisco,
The old Skystar company built and flew a version of the classic 4 with a nose wheel option before they went out of business. It was called the "Lite Squared". While the Center of gravity envelope is most likely the same as the Classic 4, they probably did some flight testing to confirm the CG envelope and loading limits for that plane. It might be worth your time to contact Kitfox Aircraft LLC http://www.kitfoxaircraft.com/ and ask if they have the weight and balance forms and instructions for weighing that model and computing the empty CG.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Float Flyr
Posted: Tue Jun 19, 2007 2:40 pm Post subject: Nose wheel and weight & balance for Classic IV |
You could do it that way... Only as long as the weight on the mains don't change. If you did it that way your W&B wouldn’t match legislated specs and you could be the only one who would know if the plane was ever in balance.
The aircraft are considered to be balanced by the location of the Centre of Gravity (CG)along the length of the aircraft. (longitudinal axis). Airplanes are given an operating envelope for the CG by their designers. Determining exactly where the empty CG is is one of those things you will have to calculate before the first flight. Then in the interests of good airmanship it is recommended that you do another W&B before every flight including things like the amount of fuel carried and the weight of pilots, passengers and sundry fishing/camping gear . All this is done through simple arithmetic. The only time the aircraft may need to be weighed is when the first empty weight CG is calculated.
The calculation of the location of the CG is made with the use of a Datum line. The datum line is just a reference point from which to make the measurements along the longitudinal axis of the airplane. Some planes have the datum so many inches in front of the nosewheel, some at the fire wall and some at the leading edge of the wing. I think there is one (C172 ?) that has the datum at the front of the spinner.
[img]cid:625183822(at)19062007-3446[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
383 Time(s) |
Kitfox III-A
