cjhukill(at)cox.net Guest
Posted: Wed Jun 20, 2007 5:44 am Post subject: OAT probe |
I just mounted an OAT probe during my RV8 panel remodel. Since I had to mount the magnetometer in the wingtip, and the OAT probe hooks up to that, I mounted the probe in the aft part of the tip, where it is shaded by the white wing tip, but is still exposed to the airflow. It's mounted thru the outboard rib, with the probe portion extending outboard into the void between the rib, and the tip rib. If you look forward into the gap between the aileron and tip you can see it, but it's shaded, and the air moves in that area. Works great.
Chris Hukill
jjessen
Posted: Thu Jun 21, 2007 5:57 am Post subject: OAT probe |
Chris, sounds good. Do you have a picture or two?
John J
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill
Sent: Wednesday, June 20, 2007 9:48 AM
Subject: OAT probe
Chris Hukill
