air.guerner(at)wanadoo.fr Guest
Posted: Sun Jun 24, 2007 1:05 am Post subject: Tailplane flutter |
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />Hi all,
The half inch play tolerance as specified by the factory means that, in a more than one degree range, the tailplanes are not balanced at all. This is a possible cause for flutter. I consider that any play in the chain between the mass balance arm and the tailplanes is unacceptable: that means zero play between TP4 and TP9 and zero play between TP 4 and TP12. The factory solution is Mod 62: replacement of the ¼� pins by 3/8� pins. This mod is known to only delay, not eliminate, the problem. As far as I know, there are 3 solutions which have been implemented successfully by builders:
- gluing TP9 and TP12 to TP4
- replace the straight pins TP14C and TP14D by AN486 taper pins
- replace the straight pins TP14C and TP14D by AN bolts
As some builders have mentioned in this forum in the past, all these solutions have their own inconveniences and must be implemented carefully, but I believe these inconveniences are far outweighed by the safety of a fully balanced tailplane in all conditions.
Remi Guerner
F-PGKL, XS S/N395 monowheel, 912S, Airmaster, 482 hours
willie.harrison(at)tinyon Guest
Posted: Sun Jun 24, 2007 1:45 am Post subject: Tailplane flutter |
I did Mod 62 and it seemed a big improvement (all holes drilled and reamed in a machine shop). 120 flying hours later it developed "a tad" of slop on one side. I have loctited that side (therefore could still remove the torque tube since loctite is on one side only). Is the idea of the AN bolt option that it clamps the two parts together? Is this a PFA approved mod?
Willie
| Quote: | Hi all,
The half inch play tolerance as specified by the factory means that, in a more than one degree range, the tailplanes are not balanced at all. This is a possible cause for flutter. I consider that any play in the chain between the mass balance arm and the tailplanes is unacceptable: that means zero play between TP4 and TP9 and zero play between TP 4 and TP12. The factory solution is Mod 62: replacement of the ¼” pins by 3/8” pins. This mod is known to only delay, not eliminate, the problem. As far as I know, there are 3 solutions which have been implemented successfully by builders:
Remi Guerner
g-iani(at)ntlworld.com Guest
Posted: Sun Jun 24, 2007 2:14 am Post subject: Tailplane flutter |
William
The idea of the bolt option is that it does two things. a) It clamps the two parts together. b) to ensure the tubes stay round a cross drilled spacer is fitted inside the TP4 tube. This is Loctited in. So you have both clamping and a glue joint but retain the ability to dismantle.
This is not PFA approved at present but has been discussed with Andy Draper in 2005.
Francis Donaldson asked me on Friday to pool any ideas we have on eliminating slop in this area. He wants to address this as part of any solution to the present problems. I will have a document ready for him, by tonight, summarising all the options (existing pins, big pins, taper pins, Bobs blocks and bolts). If anyone can think of anything else I will be glad to hear from them.
If the PFA decides that bolts is the way to go, then we will have it documented and approved very quickly.
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
ami(at)mcfadyean.freeserv Guest
Remi,
I'm not sure about that.
I had to replace my outer TP pins at 15 hours.
300++ hours later they are still OK, despite operating mostly from grass strips.
In my opinion, the pins are very accurately made. But the holes in the TP tubes are not. My new pins were set-up so that they had to be driven in; I suspect this makes the difference. The PFA requirement is now for an "interference" fit.
Duncan McF.
Posted: Sun Jun 24, 2007 3:08 am Post subject: Tailplane flutter |
Thanks Ian
The bolted option sounds like good engineering if done properly.
One other idea I have heard suggested, (by Tony Kay) is that a snug fitting inner tube is assembled, eg with Bearing Fit /retainer grade Loctite, into the torque tube, basically to make the whole thing thicker-walled and therefore to reduce the contact stress of the pin/tube contact areas. I think it would be a machine shop job to get the drilling and reaming done accurately so obviously the torque tube would have to come out.
The other option might be simply to junk the existing torque tube and substitute something beefier (thicker walled and or harder). Not sure how the CofG works out for a mono but most trigears seem to have a hefty lump of lead in the tail so they could presumably take the extra weight of a reinforced or beefier torque tube with a corresponding reduction in the ballast weight.
By the way, I think it is highly enlightened of Francis to invite ideas from owner/builders. Most of us know from uncomfortable experience what practical implications are put on any solution by the access issue, to say nothing of being "stakeholders" in the success of the outcome.
Thanks for your good work.
Willie Harrison
On 24 Jun 2007, at 11:13, G-IANI wrote:
[quote] William
e-mail mods(at)europaclub.org.uk (mods(at)europaclub.org.uk)
or direct g-iani(at)ntlworld.com (g-iani(at)ntlworld.com)
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
| [b]
Posted: Sun Jun 24, 2007 4:11 am Post subject: Tailplane flutter |
Duncan
I think they always were supplied as an interference fit.
I've noticed, however, that once they have been in and out more than
once they loosen up. Pushing a drill through to drill the nylon bush is
an awful thing to do to an accurate hole.
Better way might be to supply the nylon bush pre drilled, then bond in
the bronze bushes to fit the position of the nylon instead of the other
way round.
Re write the plans a bit?
Graham
Duncan & Ami McFadyean wrote:
| Quote: | Hi all,
Remi,
strips.
Duncan McF.
Posted: Sun Jun 24, 2007 4:17 am Post subject: Tailplane flutter |
William
Thanks for the reminder that thick wall tube is another solution.
Posted: Sun Jun 24, 2007 5:32 am Post subject: Tailplane flutter |
Graham,
I agree that they loosen up on repeated fitment, yet I had taken great care
to minimise this during the build (fitting back together only twice, less
than which was not possible).
As such, unless marginally oversize pins are supplied for the final fitting,
the design is invalidated by the build process.
Duncan McF.
josok-e(at)ukolo.fi Guest
Posted: Sun Jun 24, 2007 5:42 am Post subject: Tailplane flutter |
Ian,
Slop on the tail planes is far from a new problem, it has frequently been
reported before.
Looking through history, there has been written a lot and several
solutions have allready been suggested.
Until now, it has not been causing an accident, now it happened everybody
seems to look at it as a new problem, which it is not.
One of them is the clamp system that Bob Harrison developed.
Is that not reliable or not usefull or why is it not mentioned in this
respect?
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
Posted: Sun Jun 24, 2007 6:32 am Post subject: Tailplane flutter |
Hi! Remi
You forgot my torque tube clamps as a permanent fix for no slop ever.
Bob Harrison G-PTAG
Robt.C.Harrison
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Rémi Guerner
Sent: 24 June 2007 09:56
Subject: Tailplane flutter
Hi all,
Remi Guerner
[quote] [b]
jp(at)brannenworks.com Guest
Posted: Sun Jun 24, 2007 6:37 am Post subject: Tailplane flutter |
Is the tail flutter problem the consequence of having
easily removable stabilators?
jp
--- "R.C.Harrison" <ptag.dev(at)tiscali.co.uk> wrote:
[quote] Hi! Remi
for no slop ever.
Bob Harrison G-PTAG
Robt.C.Harrison
Posted: Sun Jun 24, 2007 6:59 am Post subject: Tailplane flutter |
Hi Bob
Where can I access details of your clamp design?
Cheers
Willie Harrison
On 24 Jun 2007, at 15:30, R.C.Harrison wrote:
Hi! Remi
Bob Harrison G-PTAG
Robt.C.Harrison
mau11(at)free.fr Guest
Posted: Sun Jun 24, 2007 8:52 am Post subject: Tailplane flutter |
Hi Robert,
Do you have pictures and/or scheme of your solution?
Michel Auvray
Builder N°145
[quote] -----Message d'origine-----
De : owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com]De la part de R.C.Harrison
Envoyé : dimanche 24 juin 2007 16:31
À : europa-list(at)matronics.com
Objet : RE: Tailplane flutter
Hi! Remi
Bob Harrison G-PTAG
Robt.C.Harrison
Hi all,
Remi Guerner
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
carl(at)flyers.freeserve. Guest
Posted: Sun Jun 24, 2007 10:35 am Post subject: Tailplane flutter |
There is a slight misunderstanding regarding where the wear in the "torque tube assembly" occurrs. The torque tube itself is a hardened (possibly crome moly) steel.
Having just implemented Mod 62 we found that there was no noticeable wear in the torque tube itself. All the wear occurred in the TP9 and TP12 components as these do not appear to be hardened steel (or as hard as the torque tube itself).
You are right about the reaming needing to be done accurately and it is advisable to drill each hole from the outside and not through the tube. The reaming should also be done from the outside and not through the opposing holes. The factory specified drill size and reamer is crucial (23/64 drill and 3/8 reamer) - dont be tempted to use a 3/8 or 9.5mm drill - it will ruin the job. Incidentally we measured the factory supplied pins and found them to be a couple of thou oversize which is probably a good thing.
The factory instructions say you should ream through the whole assembly but our experience was that this opened the holes out too much with a slightly looser fit. We practiced on a spare piece of mild steel tube before risking our engineering skills on the real thing. The purists among you will say this leads to misalignment of the holes however under the circumstances we found this simply made for a tighter fit.
We drilled and reamed all the holes individually making sure the opposing hole had a TP14 pin inserted half way. We then assembled the whole assembly once on the workbench and it was necessary to lightly hammer all the pins into place.
We thought it prudent to assemble at least once in case of a possible misalignment even though this process will have started to wear the pin holes. The risk of discovering the misalignment down the back end of the tailplane and the attendant possibility of being unable to remove the pins was not an option we wanted to contemplate. In the final event a fair amount of tapping with a hammer was needed to fully drive the pins home but has resulted in an excellent solid fit. Only time will tell how good a job this makes.
Carl Pattinson
G-LABS
PS: Im not sure the bolted option will prevent wear/ elongation of the holes. I had a Shadow pre the Europa and a lot of the tubular components were held together using bolts - in time the holes still elongated.
I did suggest to Andy that perhaps building the counterweights into the leading edge of the tailplanes would eliminate the need for the counterbalance arm but he was quick to point out this would require a substantial increase in the weight needed due to the relatively short distance between the torque tube and leading edges. Ultimately this may not be as big a problem as it seems since many Europas with heavy VP props have additional weight in the rear anyway. If this could be used to counterbalance the tailplane it would be likking two birds with one stone.
Still I am not a design engineer and I havent done the sums - and wouldnt know how to.
Posted: Sun Jun 24, 2007 10:48 am Post subject: Tailplane flutter |
The final alignment could be checked by trial fitting the torque assembly
using the shank of a 3/8" drill. The factory supplied pins are a couple of
thou oversize which is probably deliberate. Fortunately we had the help of a
licenced aircraft engineer who loaned his workshop and checked our pins with
a micrometer screw guage. Not sure of the exact dimension but they were
measurably oversize.
Or alternately make dummy pins from 3/8" steel stock - or aircraft quality
bolts. They would need to be checked with a gague to ensure they were the
correct size.
rparigor(at)suffolk.lib.n Guest
Posted: Sun Jun 24, 2007 10:54 am Post subject: Tailplane flutter |
Hello Ian
"Francis Donaldson asked me on Friday to pool any ideas we have on
eliminating slop in this area."
I am very happy with my resolution. I made pins out of 416SS ~.402" in
diameter. Interference fit between .0006" and .0008". I made a slight
dogbone (relief of a few thousands of an ") between interference contact
areas.
If I were to do it again I would make all the entrance holes slight larger
than the back side and eliminate the dogbone (I did this on a few holes).
I used paint primer as an assembly lubricant.
Search Ron Parigoris Torque Tube for a bit more detail on procedure.
A fixture for holding work is needed if the fit was as bad as mine
(trilobal holes, pins slide in with just gravity, way over 3/4"
differential motion at TE.
Burnishing is an essential (as described in my prior post) step for a true
interference fit.
Ron Parigoris
Hello Ian
areas.
interference fit.
Ron Parigoris
Hello Ian
areas.
interference fit.
Ron Parigoris
Posted: Sun Jun 24, 2007 11:22 am Post subject: Tailplane flutter |
Hello Duncan
"I agree that they loosen up on repeated fitment"
Once you do what I refer to as burnishing, the hole size remains much more
stable. I suspect that not only does it smooth the inperfections of the
wall, but expands the metal just a bit where it becomes less resiliant to
change.
I talked to a guy who used to refirbish critical gear components of Gruman
carrier aircraft. Before final reaming, he would use a hydraulic expander
to first enlarge and stabalize hole.
Making a dogbone or first hole slight larger than the second goes even
further to preventing damaging fit.
Ron Parigoris
Posted: Sun Jun 24, 2007 2:51 pm Post subject: Tailplane flutter |
Duncan
I think you are right. The surface finish on the pins might be
unsuitable, maybe the grinding marks are rubbed off when fitting?
Graham
| Quote: | Graham,
fitting, the design is invalidated by the build process.
Duncan McF.
