First flight, test pilot, dual time
phd1993
PostPosted: Thu Jul 05, 2007 2:04 pm    Post subject: First flight, test pilot, dual time Reply with quote
It would appear that my first real challenge of building a CH701 has just started - I completed my Airworthiness Certification last Friday - 6/29/2007, approximately 1 year after starting assembly of the kit. A phase I testing period of 5 hours has been included as part of the Operating Limitations. Using a "strict interpretation" of this requirement this must be completed with only the pilot on board.
Additionally for insurance coverage (under an EAA insurance program) only pilots with 2 or more logged hours specifically in a Zenith STOL CH701 would be covered. It would appear that I am now in desperate need of:
1. Test pilot for first flight.
2. Test pilot for the 5-hour Phase I flight testing.
3. Experienced pilot to provide 2 hours of dual instruction. The insurance underwriter had initially indicated this pilot needed to be a CFI but after pushing back they acknowledged that finding a CFI in Western Missouri/Eastern Kansas with CH701 experience would be next to impossible so they relented and will allow any pilot with 2 or more CH701 experience to provide "dual time".
Only "named pilots" would be covered, therefore I would need to be able to provide the insurance underwriter/agency with any pilots name, address, and appropriate Zenith STOL CH701 flight history. The plane is currently located in Harrisonville MO (KLRY)
If you can be of help, or know someone in the Midwest that might be able to help please contact me off-line at:
samhutcheson(at)kc.rr.com (samhutcheson(at)kc.rr.com)
913-268-6840 or 913-238-3807
3717 W 155th St. Overland Park, KS 66224
Sammy J Hutcheson
Zenith STOL CH701
N6412Z
larry(at)macsmachine.com
PostPosted: Thu Jul 05, 2007 2:36 pm    Post subject: First flight, test pilot, dual time Reply with quote
Hi Sam,
It'd seem easier to find a good pilot with insurance, CFI if possible,
with a willingness to put 2 - 4 hours on your plane and then get dual
time so that your insurers will cover you from that point. You're not
likely to have serious problems if you've done
your homework and it sounds like you have. Otherwise, the logistics are
awkward, but worst case, have a look at the 701 map to find the nearest
701 flying.
desperate need of:
samhutcheson(at)kc.rr.com <mailto:samhutcheson(at)kc.rr.com>
Sammy J Hutcheson
Zenith STOL CH701
N6412Z
rstone4(at)hot.rr.com
PostPosted: Thu Jul 05, 2007 3:45 pm    Post subject: First flight, test pilot, dual time Reply with quote
Harrison,
I am insured with Skysmith and after checking with several insurance companies including the one EAA recommends, I found them to be the cheapest. They will sell you full coverage which I would recommend and cancel all but libility when you have learned to fly your aircraft. This way if you break something learning, you will be covered. Here is their URL http://www.skysmith.com/   They have an 800 number shown on the web site and there is also a form for pilot history and an application
Tracy Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
NYTerminat(at)aol.com
PostPosted: Thu Jul 05, 2007 6:12 pm    Post subject: First flight, test pilot, dual time Reply with quote
Sammy, Congratulations on getting to the point where you are. How did you get a 5 Hr Phase 1?
In a message dated 7/5/2007 6:06:47 P.M. Eastern Daylight Time, samhutcheson(at)kc.rr.com writes:
1. Test pilot for first flight.Go to the factory in Mexico, Mo and get in a couple of hours with Roger.
2. Test pilot for the 5-hour Phase I flight testing.Once you have some time in under your belt and feel comfortable flying the plane, do your own Phase 1 flying. Are you current? Have you been flying at all recently? Get yourself up to speed before you fly on your own.
3. Experienced pilot to provide 2 hours of dual instruction. The insurance underwriter had initially indicated this pilot needed to be a CFI but after pushing back they acknowledged that finding a CFI in Western Missouri/Eastern Kansas with CH701 experience would be next to impossible so they relented and will allow any pilot with 2 or more CH701 experience to provide "dual time".Do this with Roger at Mexico, MO This is what I did.
Only "named pilots" would be covered, therefore I would need to be able to provide the insurance underwriter/agency with any pilots name, address, and appropriate Zenith STOL CH701 flight history.  The plane is currently located in Harrisonville MO (KLRY) I have the same insurance and they accepted my time with Roger. Good luck.
Bob Spudis N701ZX CH-701 112hrs
Sammy J Hutcheson
Zenith STOL CH701
N6412Z
See what's free at AOL.com.
phd1993
PostPosted: Fri Jul 06, 2007 2:41 pm    Post subject: Re: First flight, test pilot, dual time Reply with quote
I thought the entire email list might derive some benefit from my answer to the 5- versus 40-hour Phase I question. I registered the airplane as Experimental Light Sport Aircraft (E-LSA) instead of Experimental Amateur Built (E-AB). The E-AB registration would have required the 40 hour Phase I flight testing but would have allowed me to perform annual condition inspections. As E-LSA I needed to take the special 16-hour FAA approved course to allow me to perform annual condition inspections ON ANY E-LSA that I currently own or own in the future.
Gig Giacona
PostPosted: Sun Jul 08, 2007 7:04 pm    Post subject: Re: First flight, test pilot, dual time Reply with quote
This is probably going to upset some folks but, it is my personal feeling that the 5-hour E-LSA Phase 1 is a huge mistake that will come back to haunt the entire LSA program. 5 hours is not nearly enough time to test a 601XL or any other aircraft like it before unrestricted flight.
W.R. "Gig" Giacona
601XL Under Construction
zodiacjeff(at)msn.com
PostPosted: Sun Jul 08, 2007 8:07 pm    Post subject: First flight, test pilot, dual time Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> This is probably going to upset some folks but, it is my personal feeling that
+++ Would say I agree wholeheartedly knowing that many will disagree. One other point: the a/c that Phil describes is an HDS. Can an older HD or HDS be registered as an E-LSA as, to my knowledge, Zenith has not sought approval of the kit in that category?
Bryan M., you have a good command of the whole LSA/SP thing, what is your take on this?
SWE Area 41 jeff
future.
p.mulwitz(at)worldnet.att
PostPosted: Sun Jul 08, 2007 8:17 pm    Post subject: First flight, test pilot, dual time Reply with quote
Hi Gig,
Please keep in mind that the 5 hour test minimum is just that -- a
minimum. It is up to the builder to make sure he does sufficient
testing even in the face of freedom from government restriction.
Paul
XL fuselage
PostPosted: Mon Jul 09, 2007 2:25 am    Post subject: First flight, test pilot, dual time Reply with quote
I think this is an example of the special E-LSA certificate
originally designed for "Fat Ultralights". The way the regulation
was written it can be applied to any LSA compatible airplane that
doesn't meet the limits for an Ultralight. This all goes away after
January 31, 2008, so there is not any risk of a long term impact for
this phase 1 test limit.
On the other hand, I have not heard anything about the phase 1 test
requirements for the normal E-LSA. Since these airplanes will be
virtually identical to "Certified" S-LSA planes that require no
testing limitation it may be that 5 hours is a typical limit.
Paul
XL fuselage
Gig Giacona
PostPosted: Mon Jul 09, 2007 5:27 am    Post subject: Re: First flight, test pilot, dual time Reply with quote
Paul, I'm well aware that this is just a minimum. I'm also aware that this "loop hole" may or may not be reduced in 2008. I'm very concerned though that there are a lot of people out there that will do "the minimum."
Five hours is simply not enough time to shake the bugs out of an amateur built aircraft. All it takes is a look at how the US government has responded to perceived problems in the past to imagine how a wave of newly minted E-LSA failing will cause a backlash against the entire LSA program.
To add to the problem these E-LSAs that are being cleared out of Phase 1 after 5 hours can be used for training if I'm not mistaken.
This may be a case where we were given just enough rope to hang ourselves.
p.mulwitz(at)worldnet.att wrote:
Hi Gig,
Paul
XL fuselage
W.R. "Gig" Giacona
PostPosted: Mon Jul 09, 2007 6:05 am    Post subject: First flight, test pilot, dual time Reply with quote
I agree, I think that it is foolish.
In a message dated 7/8/2007 11:05:51 P.M. Eastern Daylight Time, wr.giacona(at)suddenlink.net writes:
kensmith(at)springnet1.co
PostPosted: Mon Jul 09, 2007 10:24 am    Post subject: First flight, test pilot, dual time Reply with quote
This 5 hour flyoff was origionally designed for registering and certifying illegal "Fat Ultralights" by January
31st, 2008. If these are not certified by then they will be ready for the scrape pile. Most all of these
aircraft are now flying and have been for some time. It is an insult to them and would be an insult to you
to ask you and your present flying 601XL to get certified and fly off a 5 hour period. It just so happened
that larger present A/B (meeting light sport critera) aircraft fell into this guide-line of ESLA before 1-31-08.
NYTerminat(at)aol.com (NYTerminat(at)aol.com) wrote:
[quote] I agree, I think that it is foolish.
In a message dated 7/8/2007 11:05:51 P.M. Eastern Daylight Time, wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net) writes:
bryanmmartin
PostPosted: Mon Jul 09, 2007 5:51 pm    Post subject: First flight, test pilot, dual time Reply with quote
There are three ways to get an E-LSA airworthiness certificate.
1. A manufacturer builds and certificates an S-LSA and then offers E-
LSA kits based on this prototype. These E-LSA kits must be built exactly
according to the plans with no deviations. As far as I know, this option
is not available for any Zenith aircraft yet.
2. An S-LSA can be converted to E-LSA status. This could be done with an
AMD built S-LSA CH601XL.
3. Any aircraft that meets the definition of LSA but does not meet the
legal definition of Ultralight and has never had an airworthiness
certificate issued for it can be registered as an E-LSA under the so
called "fat ultralight" rule. This is the rule that allows Zenith
aircraft kits to be registered as E-LSAs. This option expires on January
31, 2008.
The five hour test period is probably reasonable for the first two
options or for a factory built "fat ultralight" that has already been
flying for some time. It is probably not reasonable to expect a five
hour test period to be sufficient for an amateur built kit plane with
the usual builder modifications.
feeling that
the entire
your take on this?
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
Bryan Martin
do not archive.
kmccune
PostPosted: Sat Sep 22, 2007 9:04 am    Post subject: Re: First flight, test pilot, dual time Reply with quote
So after Jan 2008 it has to be registered as a S-LSA then converted... how does this affect my ability to perform maintenance on it? Assuming I have taken the 16 hr class?
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
