pdwalter(at)bigpond.net.a Guest
Posted: Tue Feb 14, 2006 10:56 pm Post subject: Rudder |
On the Rudder, does the 913 counter balance skin go over or under the 901 rudder skin. The plan makes it hard to tell. It would seem logical to have it over so the join running is with the air flow - I am just not sure.
Paul Walter
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
davcor(at)comcast.net Guest
Posted: Tue Feb 14, 2006 11:37 pm Post subject: Rudder |
Paul,
look closely at drawing 7 grid f/g | 5/4 dashed lines are hidden. Not that over looked this or anything...
squeeze 'em too don't buck...
Dave
RV7 - N898DC (rsvd)
emp done, wings done finally, fuse firewall... de-burring and dimpling and countersinking
when you get to your tanks, find (on ebay) an Orndorf video showing the tank build process (RV6 works), realize the stories aren't as bad... dive in. Don't forget to visit rvproject.com
| Quote: | -------------- Original message --------------
Paul Walter
sshook(at)cox.net Guest
Posted: Wed Feb 15, 2006 10:31 am Post subject: Rudder |
I had the same question…the plans are correct. If memory serves me correctly, the dashed line has the skin edge into the wind.
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Paul Walter
Sent: Tuesday, February 14, 2006 11:54 PM
To: rv7-list(at)matronics.com
Subject: Rudder
Paul Walter
John Brunke
Posted: Wed Feb 15, 2006 11:21 am Post subject: Rudder |
Paul,
If you look in the archives there was a discussion on this about a year ago.
John Brunke
mk325ef(at)yahoo.com Guest
Posted: Wed Feb 15, 2006 5:57 pm Post subject: Rudder |
Hi Paul,
The counterbalance skin goes over the left and right skins. I edge rolled the counterbalance skin to put a slight angle on it so it sits nicely flat on all edges against the skins.
Greg
"J. Brunke" <jdoody727(at)comcast.net> wrote:
[quote] v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> st1\:*{behavior:url(#default#ieooui) } Paul,
John Brunke
truflite(at)yahoo.com Guest
Posted: Wed Feb 15, 2006 8:37 pm Post subject: Rudder |
Hooboy, I hope it works for you, because I think you
are incorrect in putting the counterbalance skin on
top. The plans show two areas each side that require
you to taper the edges of the CB skin, not unlike
honing a razor blade. This provides a gentle ramp for
the rudder skins to lay onto, reducing any possibility
of kinking the skin near the joint of the CB and
rudder skin. Reference Drawing 7, section G 10, and G
5
--- Greg C <mk325ef(at)yahoo.com> wrote:
[quote] Hi Paul,
Greg
url(#default#VML) }
Paul,
John Brunke
Brad Oliver
Posted: Thu Feb 16, 2006 1:33 pm Post subject: Rudder |
Dave is correct... the rudder skin goes OVER the counterbalance skin.
This has been brought up several times in several places, all with the
same conclusion... the dashed lines on the plans indicate the rudder
skin is on top of counterbalance skin.
If you do as Dave says and taper the counterbalance skin, as the plans
indicate, you will be surprised at how flat the rudder skin sits on top
of the counterbalance.
But hey, don't take our word for it... call Van's if you need
verification.
Good luck!
Brad Oliver
RV-7 Livermore, CA
www.rv7factory.com
[quote] ------
