longg(at)pjm.com Guest
Posted: Tue Jul 10, 2007 1:17 pm Post subject: Z-19 |
I would like to hear from anyone who has implemented this diag
successfully. I am working on a Subaru with two batteries, one
alternator and two fuel pumps. I would like to hear about your could of
done, should of done, could do better next time etc. How many gotchas
are in the design and so on. Pictures would be great if you have them.
Some of us pilots are pessimists even before we wake up!
Glenn
rvbuilder(at)sausen.net Guest
Posted: Tue Jul 10, 2007 2:31 pm Post subject: Z-19 |
Many others out there are going with Z-19 so please share your experiences with the list. Bob can't improve things if he doesn't know about it!
Michael Sausen
-10 #352 Limbo
Paul LeDoux
Posted: Tue Jul 10, 2007 2:58 pm Post subject: Z-19 |
I am going with the Z-19 Rear batteries in an RV-8 with the 2.5 SC engine with Supercharger.
My question is why not be able to operate the second Fuel Pump from either battery?
Seems like it would give another option for keeping the fuel flowing. Mine will be wired this way.
Thanks to Bob N. for all he does.
Paul
See what's free at AOL.com.
Posted: Tue Jul 10, 2007 4:55 pm Post subject: Z-19 |
Hi Glenn,
I don't know about the diagram number, but your items match mine and I
did wire things
very closely to the AeroElectric diagrams. Absolutely no problems so
far, but for
one early on, not having a contactor replacing my internal starter relay
power.
The link below perhaps offers a different schematic view.
http://www.macsmachine.com/images/electrical/full/primary-wiring.gif
Lots of images on the engine page and electrical page
Good luck,
Larry McFarland 601HDS - Subaru power, one alternator and 4 fuel pumps
at www.macsmachine.com
longg(at)pjm.com wrote:
Glenn
mikefapex
Posted: Thu Jul 12, 2007 7:01 am Post subject: Re: Z-19 |
I have a Z-19 switches usage clarification question. I am planning for this design in a GEO/Suzuki powered aircraft.
I read the Z-19 diagram last night, I think I understand most of it.
The switches I've tried to
match them with their location on the diagram, and I think I've done
that. What I am not sure of is: which switches are used at aircraft
startup and/or flying? And is there more done with switches once the
engine is running?
I labeled the switches from left to right, A - H
A - #2 Fuel Pump
B - Secondary Power
C - Primary Power
D - Start
E - E-Bus Alt Feed
F - DC Pwr Master/Bat/Off - this is one I don't understand the purpose
of the three way position. When would you use what?
G - Alt Field - is this a circuit breaker? I did not find it on the
diagram. To be honest I'm not sure what 'Alternator Field' really means. Yes, I am an noob.
H - Eng Bat Auto/On/Off - Again, not understanding the purpose of the
3 position switch.
My best guess for starting the aircraft would be the sequence: F to
Bat, C on, B on, Start
Clarification on these and their use is appreciated. Thanks,
Posted: Thu Jul 12, 2007 9:47 am Post subject: Z-19 |
Thanks Mike,
Agreed, I asked myself the same question when reading the diagram. I
would also like to see at least a dashed line showing the leads for the
two batteries. In a dual battery installation, the setup is not always
obvious. Thanks to others for their opinions and suggestions.
Glenn
Posted: Thu Jul 12, 2007 1:36 pm Post subject: Z-19 |
Larry,
Great job on the Zodiac - what a huge amount of work! You've got some
heavy duty pitot plumbing there! As you said, I see a few variations on
Bob's theme, but a job well done. I cannot see the add'l fuel pumps on
this schematic? I would be interested to see how you laid the wiring out
for them. I'm assuming you are only running 1 at a time?
frank.hinde(at)hp.com Guest
Posted: Thu Jul 12, 2007 1:52 pm Post subject: Z-19 |
I hope not....At least 2 for Take off and landing.
Frank
Soobed Zodiac 400 hours sold
Lyc'd RV7a 170 hours
Posted: Thu Jul 12, 2007 5:12 pm Post subject: Z-19 |
Hi Glenn,
The pumps are labeled Aux L & Aux R on the switch diagrams right above
the buses.
The master (main bus) and boost (essential bus) are both run on takeoff
and plumbed in parallel. The Aux L and Aux R
pumps (essential bus) are individually switched to pump from the wing
tanks to the header as needed thru a fuel selector valve.
The labeled connections feeding back thru the console give away where
they are going and they are all Facet 105
pumps at 5 or 7 amps. The Aux pumps on the wing tanks are wired to a
single 5 amp fuse in the main bus. I've labeled the
pumps, but find that colored shrink wrap on the switch handles, yellow
for main and boost and blue for aux pumps
helps find the right switches faster than trying to read small lettering
with my progressive-lens glasses. Anything outside the
fuselage has a ground wire back to the forest-of-tabs ground on the
firewall. I never run more than one wing pump at a time.
Note: Header tank overflow was plumbed to drain at the right wing joint
as I don't like fuel or fumes anywhere near the engine exhaust. It's not
something perhaps you were concerned with just now, but I thought it
worth noting.
You should be able to make out the pictorial arrangement for all that's
there, sometimes not so obvious.
Thanks for the compliments. It was a lot of work, but I miss it now and
must progress to a next project.
Larry
Larry,
nuckollsr(at)cox.net Guest
Posted: Fri Jul 13, 2007 2:02 pm Post subject: Z-19 |
At 06:52 PM 7/10/2007 -0400, you wrote:
| Quote: | I am going with the Z-19 Rear batteries in an RV-8 with the 2.5 SC engine
with Supercharger.
battery?
How many failures are you planning to stack? I've seen some
airplanes wired where the owner was able to select backups
to backups . . . the architecture offered a hose of variables
for powering things up in case this failed, and then that failed
too, etc.
The probability of dual failures on any one tank of fuel is
exceedingly low. Properly maintained RG batteries (when
installed to accommodate relatively fragile lead posts)
are exceedingly reliable. The failure mode effects analysis
process is a deduction of all the what-if's but for our
purposes, we don't need to go more than one layer deep.
Given the quantum jump in alternator and battery reliability,
you can comfortably assume that altenrator failure will be
rare and both properly maintained batteries will be there
when you need them.
| Quote: | Thanks to Bob N. for all he does.
My pleasure sir. I'm pleased that you find the efforts
useful.
Paul LeDoux
Posted: Sun Jul 15, 2007 4:40 pm Post subject: Z-19 |
Thanks a million Bob, my days with the Saturn V moon rocket, triple module redundancy, sometimes rears it's head. Think I will go with your original diagram.
Paul
Get a sneak peak of the all-new AOL.com.
Posted: Mon Jul 16, 2007 5:18 am Post subject: Z-19 |
At 08:39 PM 7/15/2007 -0400, you wrote:
| Quote: | Thanks a million Bob, my days with the Saturn V moon rocket, triple module
diagram.
Paul
Understand. I have a client right now that believes it is
better to have two position sensors for a flap system than
just one. I'm trying to help him understand that if you can
design your system to be tolerant of any single failure
then one sensor by definition will suffice. If failure of
the pilot to KNOW flap position at all times creates a
strong potential for hazard, then you need THREE sensors
and a validity evaluation system that compares all three
data values, tosses out the one that is bad and annunciates
the failure (cause we're now down to two . . . one more sensor
crap and we're toast). Two sensors in a fail-proof approach
is not sufficient.
Figure Z-19 presupposes that all the things I think I understood
about engine operations are true at the time I crafted the
diagram. If some new condition or requirement comes along concerning
these automotive conversions (or I mis-understood some feature
that has always existed) then some shuffling of the switches
and wires may be in order.
So I hope that you nor anyone else here on the List believes
that Z-19 or any other architecture is somehow sacred, golden,
or guaranteed to please for ever and ever amen. It's ALWAYS
good to question and to raise your own alarms should you
perceive that common understanding of requirements has not yet
been achieved.
This is why I always query an individual about perceptions of
shortfall when changes to the Z-figures are suggested. I
and everyone else on the List NEEDS TO KNOW when some new,
useful or necessary feature is called for. So please don't
take my questioning as some defense of my ideas at the expense
of your own. Our common goal should be the elegant solution.
Maximize functionality and safety with the minimum of parts
count, weight and cost while keeping operating procedures
as simple as we can. When things are going sour in the cockpit,
you don't want a feature of poor human factors design adding
to your misery.
