John H Murphy
Joined: 03 Jan 2007 Posts: 78 Location: Henderson, NV
Posted: Fri Jul 13, 2007 3:33 pm Post subject: Flying characteristics- Kolb Firestar vs. Quicksilver Sprint |
Does anyone have experience with any of the Quicksilver aircraft, especially the MX Sprint with respects to how it flys compared to the Kolb Firestar? An ultralight instructor here in Boulder City, NV insists that the Kolb is much more complicated to fly than any of the Quicksilver aircraft. I guess the real question should be: Is the Kolb more forgiving than the Quicksilver???
DBforfun
Posted: Fri Jul 13, 2007 3:51 pm Post subject: Flying characteristics- Kolb Firestar vs. Quicksilver Sprint |
I have owned Quicksilver aircraft. The quicksilvers have so much drag that they stick close to the airport. They burn up a lot of fuel to just fly. If you actually want to fly somewhere and then get back again go with a Kolb. The kolb is only slightly more complicated to fly but that is only if you are learning. If you know how to fly or once you learn how to fly the Kolb is a much better aircraft and much more enjoyable to fly. Plus you can quickly fold it up and put it away.
Dan
In a message dated 7/13/2007 4:34:15 P.M. Pacific Daylight Time, jhm9812(at)yahoo.com writes:
| Quote: | --> Kolb-List message posted by: "John H Murphy" <jhm9812(at)yahoo.com>
http://forums.matronics.com/viewtopic.php?p=123682#123682bsp; --> ======================
Get a sneak peak of the all-new AOL.com.
rlaird
Posted: Fri Jul 13, 2007 3:53 pm Post subject: Flying characteristics- Kolb Firestar vs. Quicksilver Sprint |
There's absolutely NO comparison... I owned a Quicksilver 3-axis MXL
for a couple of years, and then later flew several Kolb models (and
currently own a MkIIIC)... the Kolbs all fly SO much better, much,
MUCH stronger, and more balanced and will fly hands-off (assuming they
are rigged correctly). They will also fly as slow as a Quick, but
will also fly MUCH faster. The difference is night and day. And
there is -nothing- "complicated" about flying a Kolb... I find the
Quicks more "complicated" since the stick is way off the right, and
the instrument panel (on mine) was off to the left.
I will say, though, that my Quick -- being my first ultralight -- was
probably not rigged as tightly as it could be, but, even so, I can't
imagine it being better in -any- of the characteristics than a Kolb.
As for being "forgiving"... well, that's a pretty nebulous word... two
pilots, each trained how to fly their craft properly, would probably
find each plane "forgiving".
My $0.02...
-- Robert
On 7/13/07, John H Murphy <jhm9812(at)yahoo.com> wrote:
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Lanny Fetterman
Joined: 10 Jan 2006 Posts: 37 Location: Catawissa Pa.
Posted: Fri Jul 13, 2007 4:20 pm Post subject: Flying characteristics- Kolb Firestar vs. Quicksilver Sprint |
John, I went from a Quicksilver MX to a Firestar II. The Firestar is
quicker in all respects. Lift off, climb and roll, not difficult to fly
just way quicker then the MX. You con doo it! (My Arnold Swartsnegger (sp)
impression.) Lanny Fetterman FSII N598LF
_________________ Lanny Fetterman Firestar II N598LF |
jlsk1(at)frontiernet.net Guest
Posted: Fri Jul 13, 2007 5:14 pm Post subject: Flying characteristics- Kolb Firestar vs. Quicksilver Sprint |
If this is the real question, clarify "more forgiving" in what respect????
Kolbs do what you ask of them, within their limitaions. I would imagine the same is true with the Quicksilver. : ) Jim
Try Them both, with an experienced pilot/CFI
