weeav8ter(at)grandecom.ne Guest
Posted: Wed Feb 15, 2006 6:30 am Post subject: defrosters |
Has anyone installed or thought about installing a defroster system? I keep thing about running 2' hoses up to each side of the glare shield. Maybe some of you who have been flying for awhile, Vic, could tell me if you think it's necessary.
Nothing can give you a bad hair day quicker than coming in IFR, low ceilings and you can't see out the front window!!
Wayne Edgerton
# 40336
DOUGPFLYRV(at)aol.com Guest
Posted: Wed Feb 15, 2006 6:37 am Post subject: defrosters |
I am flying a 7 with 2 computer cooling fans in the glare shield to serve as defog fans.....works great and have needed them several times. Doing the same on the 10.
Doug
40372
rv10es(at)earthlink.net Guest
Posted: Wed Feb 15, 2006 6:51 am Post subject: defrosters |
can you post a picture?
rob kermanj
rv10es(at)earthlink.net (rv10es(at)earthlink.net)
On Feb 15, 2006, at 9:36 AM, DOUGPFLYRV(at)aol.com (DOUGPFLYRV(at)aol.com) wrote:
| Quote: | I am flying a 7 with 2 computer cooling fans in the glare shield to serve as defog fans.....works great and have needed them several times. Doing the same on the 10.
Doug
40372
Posted: Wed Feb 15, 2006 7:45 am Post subject: defrosters |
Will have to shoot pics when go to A/P next time.
dp
jeremy.p.harris(at)boeing Guest
Posted: Wed Feb 15, 2006 7:51 am Post subject: defrosters |
Rick and I installed a defroster on our RV-10 using some tees, vent parts from a Cherokee, and a shutoff valve. There's some pics on our website of the various components.
http://jharris.net/Aviation/RV_10.htm
Jeremy P. Harris
Integrated Missile Defense
BMDS Architectures Lab
The Boeing Company
Washington, DC
Desk: (703) 414-6057 Dept: AV-2L-B27T
Cell: (703) 627-6500
Fax: (703) 414-6372
MC: 793C-G007
Office: 825B
From: Wayne Edgerton [mailto:weeav8ter(at)grandecom.net]
Sent: Wednesday, February 15, 2006 9:28 AM
Subject: RV10-List: defrosters
Wayne Edgerton
# 40336
Posted: Wed Feb 15, 2006 8:00 am Post subject: defrosters |
Thanks. No big hurry.
rob kermanj
On Feb 15, 2006, at 10:42 AM, DOUGPFLYRV(at)aol.com (DOUGPFLYRV(at)aol.com) wrote:
| Quote: | Will have to shoot pics when go to A/P next time.
dp
Posted: Wed Feb 15, 2006 8:01 am Post subject: defrosters |
Thanks, I will look.
Do Not Archive.
rob kermanj
On Feb 15, 2006, at 10:50 AM, Harris, Jeremy P wrote:
| Quote: | Rick and I installed a defroster on our RV-10 using some tees, vent parts from a Cherokee, and a shutoff valve. There's some pics on our website of the various components.
Jeremy P. Harris
The Boeing CompanyWashington, DCDesk: (703) 414-6057 Dept: AV-2L-B27TCell: (703) 627-6500Fax: (703) 414-6372MC: 793C-G007Office: 825B
From: Wayne Edgerton [mailto:weeav8ter(at)grandecom.net (weeav8ter(at)grandecom.net)] Sent: Wednesday, February 15, 2006 9:28 AMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: defrosters
Wayne Edgerton
# 40336
deruiteraircraftservices( Guest
Posted: Wed Feb 15, 2006 8:13 am Post subject: defrosters |
Hi,
I'm not to sure this set up will work on the ground without a fanmotor of some description. You'll need quite a bit of forward motion to get air to move through the entire system. In addition, the windscreen tends to steam up when on the ground before and after engine start, ie, when you do not have forward movement. It is even doubtful you'll have sufficient forward motion during taxi.
The set up with the cooling fans out of a computer is a better option nad it's not the first time I've heard about it.
I know there's RV4's and -6's flying with them.
jjessen(at)rcn.com Guest
Posted: Wed Feb 15, 2006 8:20 am Post subject: defrosters |
Any chance we can remember the
on some of these casual posts?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rob kermanj
Sent: Wednesday, February 15, 2006 8:00 AM
Subject: Re: RV10-List: defrosters
rob kermanj
dp
sam.marlow(at)adelphia.ne Guest
Posted: Wed Feb 15, 2006 8:33 am Post subject: defrosters |
Will the fan motors interfere with the EFIS displays?
RAS wrote:
| Quote: | Hi,
| Quote: | ----- Original Message -----
Sent: Wednesday, February 15, 2006 4:00 PM
Subject: Re: defrosters
Do Not Archive.
rob kermanj
Jeremy P. Harris
The Boeing Company Washington, DC Desk: (703) 414-6057 Dept: AV-2L-B27T Cell: (703) 627-6500 Fax: (703) 414-6372 MC: 793C-G007 Office: 825B
From: Wayne Edgerton [mailto:weeav8ter(at)grandecom.net (weeav8ter(at)grandecom.net)] Sent: Wednesday, February 15, 2006 9:28 AM To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) Subject: defrosters
Wayne Edgerton
# 40336
Posted: Wed Feb 15, 2006 9:58 am Post subject: defrosters |
Hi,
I would be inclined to think that they don't. They're normally working in very close proximity to the computer mainboards, if there were any problems along those lines the computer would have problems(?)
Tim(at)MyRV10.com Guest
Posted: Wed Feb 15, 2006 10:30 am Post subject: defrosters |
My EFIS has fans built right into the back. Can't see why
one would be a problem and another wouldn't unless maybe
it's a real noisy fan.
RAS wrote:
[quote] Hi,
rick.conti(at)boeing.com Guest
Posted: Wed Feb 15, 2006 10:49 am Post subject: defrosters |
What does “Do Not Archive” do to an email?
Thank You
Rick Conti
office: 703-414-6141
cell: 571-215-6134
Sent: Wednesday, February 15, 2006 11:20 AM
Subject: RE: defrosters
rob kermanj
dp
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Wed Feb 15, 2006 11:29 am Post subject: defrosters |
Hi Doug ...
I'm thinking the same thing about defrost and agree from similar experience.
What inch measurement fans are you flying with and do you get any fan noise?
Thanks for the info ...
Jerry Grimmonpre'
RV8A
DO NOT ARCHIVE
DOUGPFLYRV(at)AOL.COM Guest
Posted: Wed Feb 15, 2006 1:54 pm Post subject: defrosters |
Sorry, I do foerget. I seldom make post and not in the habit. Will try to do better.
DP
DO NOT ARCHIVE
Posted: Wed Feb 15, 2006 1:55 pm Post subject: defrosters |
Don't know as I do not have EFIS in the 7. Will find out when the 10 flies.
Doug
DO NOT ARCHIVE
Posted: Wed Feb 15, 2006 2:18 pm Post subject: defrosters |
Jerry, I don't know exact size of fafans as we bought the 7. I purchased 2 fans for the 10...I think 3". There is no ducting, just cabin air criculating, but works fine.
doug
DO NOT ARCHIVE
owl40188(at)yahoo.com Guest
Posted: Wed Feb 15, 2006 2:47 pm Post subject: defrosters |
I wonder if these would work well in the tunnel area to keep it cooler.
Niko
40188
steveadams
Posted: Thu Feb 16, 2006 4:40 am Post subject: Re: defrosters |
Please bear with me if this is a stupid idea, as I am not building a 10. There has been some discussion of problems with a lot of heat in the tunnel area. If the air in the tunnel is positive pressure relative to the cabin, and the air is quite hot, wouldn't it be possible to duct some of that heat through a scat hose to a vent on the glare shield? Unwanted heat converted to a useful purpose, no wiring, fans to fail, possible radio noise etc. It seems to me the air flow and amount of heat that a little computer cooling fan would put out would be insufficient to do anything more than clear a little interior fog off a small portion the the windscreen. Just a thought.
jesse(at)itecusa.org Guest
Posted: Fri Feb 17, 2006 4:38 am Post subject: defrosters |
We have a cooling fan system from Aircraft Spruce that has three ports, two going to the radio stack and one unused. That could easily be run to a hole in the glare shield to be used as a defrost. In fact, a fan with more ports could be used and have two or more defrost ports. It would be always on, but I can’t imagine that that would make much difference, since the fan is always running anyway, and the air is just from under the glare shield, so it shouldn’t be too hot or cold except maybe just starting out. Any reason that this shouldn’t work?
Thanks.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Fax: 815-377-3694
I am in Ecuador until May, 2006. If you have questions regarding I-TEC, please call the office at 352-465-4545. If you would like to talk to me, please call me at 352-505-1899. This number won't always be on, but it has voicemail that will get to me in Ecuador.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RAS
Sent: Wednesday, February 15, 2006 11:12 AM
Hi,
