		k9hxt(at)sbcglobal.net Guest
				 Posted: Wed Feb 15, 2006 9:38 pm    Post subject: Tow Bar |
				Does anyone know who makes a tow bar for the RV-7A ?? I bought one about 5 years ago for a RV-6A but don't remember who the guy was? It was real simple and worked fine etc. Had a spring loaded pin that secured it into the socket heads of the screws that hold on the nose wheel pant.
   Larry, RV-7A about ready to fly!!
 "LIMA TANGO SENDS"
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		diff(at)foothill.net Guest
				 Posted: Thu Feb 16, 2006 7:21 am    Post subject: Tow Bar |
				Larry,
 	I did some searching and finally ordered a Bogert towbar from ACS (their #
 13-01811 for $74.00).  Short story was it didn't work properly so I called
 Richard Bogert, the owner, and he sent me modified parts at no charge which
 solved the problem after I re-drilled the pivot hole to fit my wheel pant.
 I also clamped on a simple stop per his suggestion to hold the bar in closed
 position so it won't pop off when steering the nosewheel.  I think he may be
 adding a stop/latch in the future.  If he does, it will be one trick unit.
 Lightweight, good quality, and collapsible for stowing in the baggage
 compartment.  I would give him a call.  He is super nice. info(at)bogert-av.com
 or 509-736-1513.
 Scott Diffenbaugh
 RV-7A N814SD FAA inspection today!
		jack.lockamy(at)navy.mil Guest
				 Posted: Fri Feb 17, 2006 7:36 am    Post subject: Tow Bar |
				Cleveland Tool Co. sells a tow bar made specifically for tri-gear RVs for about $50.  You can order it online from their catalog.  It also collapses for easy storage in the baggage compartment.  I have two of them... one for the hangar and one kept in the plane.
 They work perfectly!
 Jack Lockamy
 RV-7A N174JL 140 hrs
 Camarillo, CA
 www.jacklockamy.com
