		alfolavf(at)online.no Guest
				 Posted: Thu Feb 16, 2006 3:03 am    Post subject: New landing light for the RV-7 and -8 |
				HI!
 I just saw that Vans has a new landing light system in their online-store.
 It's designed for installation in the wing tips (2 in each), gives a total of 300W (4 x 75W)
 It can only be installed in the new wingtips with the straight TE. (W-715-1)
 Has anyone experience with this product?
 Is it better than the Duckworks 100W for example? Easy to install?
 It appeals to me that I don't have to cut in the nice LE of my QB-wings... and more light ofcourse.
 Best regards Alf Olav Frog / Norway
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		tylerii(at)infoave.net Guest
				 Posted: Thu Feb 16, 2006 6:40 am    Post subject: New landing light for the RV-7 and -8 |
				Ordered these, and when they came in I hooked them up to measure "in
 rush current" as I noticed that  they are the high wattage minature
 halogen. In rush current was greater than 20 amps for about 8 seconds
 until they came up to full bright. I then measured the in rush current
 for the Duckworth and found that the current barely exceeded 10 amps for
 less than a second. Also the heat generation in the confined space in
 the wing tip and the fact that the composite laminate of the wing tip
 was barely adequate for the loads, I felt that I should just go with the
 Duck lights in the wings. Sent the other lights back.
 That's just my opinion
 Tyler RV7A N442MN
 Alf Olav Frog wrote:
  	  | Quote: | 	 		  HI!
		lhelming(at)sigecom.net Guest
				 Posted: Thu Feb 16, 2006 7:04 am    Post subject: New landing light for the RV-7 and -8 |
				And demanding a bigger alternator perhaps.
 Indiana Larry, RV7 SunSeeker 85+ hours flying
  	  | Quote: | 	 		   HI!
  of 300W (4 x 75W)
  (W-715-1)
		182ppl(at)comcast.net Guest
				 Posted: Thu Feb 16, 2006 9:32 am    Post subject: New landing light for the RV-7 and -8 |
				I do not have any experience with the product that Vans sells but the
 Creativair.com landing lights look very similar.
		dhall(at)donka.net Guest
				 Posted: Thu Feb 16, 2006 9:12 pm    Post subject: New landing light for the RV-7 and -8 |
				A friend has wing tip landing lights.  They don't really light up front and
 center all that well because the notched tip introduces its own obstruction.
 It's not unusable for that flaw, and they are nifty otherwise.  I wanted to
 be sure of plenty of forward light, so I went with duckworks HID in the
 leading edge.  Mine are only lighting up my shop at this point...
				 Posted: Fri Feb 17, 2006 6:14 am    Post subject: New landing light for the RV-7 and -8 |
				Just a point about the amount of light that projects with the Duckworks LE
 lights.  I have found that they work just fine at lighting the runway and
 taxi way for my tailwheeler.  I adjusted the lights so they shine down as
 much as possible with the provided kit.  The lack of watts is not a problem.
 "Please use the information and opinions I express with responsibility, and
 at your own risk."
