ch701builder
Joined: 07 Feb 2006 Posts: 119 Location: N38.9947,W105.1305,ALT. 9,100'
Posted: Thu Aug 02, 2007 5:36 am Post subject: 701 builders, bottom fuselage |
All, I am trying to do some pre-drilling holes in the bottom fuselage
(7F2-3). To start off with, my plans 4th, 6th printing, show that there
is 303mm between cl to cl of 7F1-3 and 7F1-4, but the
assembly/construction manual 1.2 04/2003, ( Fuselage Section 1 - page 3
of 10) states that there should be 285mm between the two. What are some
of you scratch builders using, or what is the factory pre-drilled holes
measuring?
Keith
N 38.9947
W 105.1305
Alt. 9,100'
CH701 -- scratch
This e-mail and any files transmitted with it may be proprietary
and are intended solely for the use of the individual or entity to
whom they are addressed. If you have received this e-mail in
error please notify the sender. Please note that any views or
opinions presented in this e-mail are solely those of the author
and do not necessarily represent those of ITT Corporation. The
recipient should check this e-mail and any attachments for the
presence of viruses. ITT accepts no liability for any damage
caused by any virus transmitted by this e-mail.
txpilot
Posted: Thu Aug 09, 2007 6:44 am Post subject: Re: 701 builders, bottom fuselage |
Keith,
According to my plans, the 303mm is NOT cl to cl. It is the dimension from 7F1-4 front to the back of 7F1-3. In order to hit the centers of the flanges, you need to subtract around 20mm for you pre-drilled hole distance.
Hope this helps.
Dan Ginty
