flysrv10(at)gmail.com Guest
Posted: Fri Aug 03, 2007 5:31 am Post subject: high oil temp |
Thank you for the info.
Rob.
On Aug 2, 2007, at 10:29 PM, ddddsp1(at)juno.com (ddddsp1(at)juno.com) wrote:
I have the louvers on the bottom of the cowl..........they do work. If you just install the SW cooler and do NOT put in the louvers don't expect much of a change. AMF when I talked to the people selling the "better" oil cooler for $500 they would not promise cooler oil temps without adding the louvers. Airflow over the cooler is the issue in the RV10...........NOT the cooler itself.
IMHO Dean 805HL
________________________________________________________________________
/2-2125045-32">Get Juno DSL - the easier, safer broadband!
Quote: |
| [b]
Posted: Fri Aug 03, 2007 5:33 am Post subject: high oil temp |
Thanks.
Rob.
On Aug 2, 2007, at 7:13 PM, pilotdds(at)aol.com (pilotdds(at)aol.com) wrote:
[quote]In my humble experience ,verified with before and after testing ,the oil cooler without the louvres do improve cooling.I installed the cooler with the intent of placing the louvres later and found it unnecesary.The heating of the firewall seems to cause the oil cooler to become a heat sink .Additional airflow over the cooler can only help but may not be necesary.On sat 7-21 I was held on the ground for 40 minutes in 106 degree heat,oil temp reached 228 on the ground.On release and 1000 fpm climbout ,110 mph ,three large men aboard temp went to 207.Leveling at 5500 temp went to 195.
Hope this helps
bill@airflow
Posted: Fri Aug 03, 2007 5:36 am Post subject: Re: high oil temp |
Dean,
Thanks for the invite to share data. I will be happy to do that upon my return from a planned family vacation which starts in a few minutes. I will be back Aug. 10 midday for half a day and can post again then.
We are willing to share data but I do not want it to sound like a commercial. I will present it as charts, along with our observations, that will be available to anyone that is interested so that they can draw their own conclusions.
My wife its past time to go...
Bill
Posted: Fri Aug 03, 2007 5:48 am Post subject: high oil temp |
Thank you Bill. Your information will be very helpful.
Rob.
On Aug 3, 2007, at 9:36 AM, bill(at)airflow wrote:
Quote: |
Dean,
again then.
Bill
http://forums.matronics.com/viewtopic.php?p=127316#127316
tintopranch
Posted: Fri Aug 03, 2007 7:38 am Post subject: Re: high oil temp |
I live in TX and did see 200+ oil temps on climb out, I added an extra set of van's cowl vents on the bottom of the cowl under the oil cooler and have seen my oil temps stay under 200 on climb outs now. I also sealed up all of the large gaps in my baffles. So it does appear the oil cooler needs some help on hot days in a climb or slow flight.
_________________ MARK SUTHERLAND
RV-10 40292
Flying since June 07 |
rnewman(at)lutron.com Guest
Posted: Tue Aug 07, 2007 6:22 am Post subject: high oil temp |
I've been following along on this thread and am a bit confused by the
references being made to "with louvers or without louvers". Can some
one please clarify this or direct me to some pictures. Are these the
cut-out in the bottom of the cowl??
I will not be using the van's firewall forward kit as I am using an
engine and many of the accesories from Cherokee 6-260 including the oil
cooler. (its the pma'd one stewart warner one). I'm planning on
just buying the ff accesories I need piece wise as needed, (such as the
filtered air box).
Thanks for the input.
( finally done with slow build chapter 29!!)
-Bob Newman
LloydDR(at)wernerco.com Guest
Posted: Tue Aug 07, 2007 7:05 am Post subject: high oil temp |
The louvers are part of the Finish kit and get installed into the lower
cowling to help dissipate heat. Some builders have been choosing to not
install them, and others have installed them. They are installed from
inside the cowl, and can be added at a later date if necessary, but if
you do it after paint extra care will have to be taken, but definitely
doable.
Dan
N289DT RV10E Flying
scottmschmidt(at)yahoo.co Guest
Posted: Tue Aug 07, 2007 10:52 am Post subject: high oil temp |
Cool, thanks for the link. I was confused, I did not know that people were adding more. At least now I have an option for additional airflow.
THX
Dan
N289DT RV10E Flying
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Tuesday, August 07, 2007 12:03 PM
Subject: Re: Re: high oil temp
I think there may be a misunderstanding. The louvers most of us are talking about are not included in the kit but are purchased http://www.aviationtechproducts.com/html/accessories.html . I think everyone has the louvers installed that Van's included, but many are adding additional louvers to increase airflow. http://www.aviationtechproducts.com/html/products_pics.html#louver11
Scott Schmidt
scottmschmidt(at)yahoo.com
----- Original Message ----
Sent: Tuesday, August 7, 2007 8:05:23 AM
Subject: RE: Re: high oil temp
--> RV10-List message posted by: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
doable.
Dan
N289DT RV10E Flying
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Newman
Sent: Tuesday, August 07, 2007 10:21 AM
Subject: Re: high oil temp
--> RV10-List message posted by: "Bob Newman" <rnewman(at)lutron.com>
filtered air box).
-Bob New10-List" target=_blank>http://www.matronics.com/Navigator?RV10-List
mritter509(at)msn.com Guest
Posted: Tue Aug 07, 2007 3:43 pm Post subject: high oil temp |
In addtion to the louvers that come with the finish kit I installed the
louvers sold by Alex D. They really helped bring the high oil temp down.
[quote]From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Date: Tue, 7 Aug 2007 11:05:23 -0400
doable.
Dan
N289DT RV10E Flying
