Float Flyr
Posted: Fri Aug 10, 2007 4:37 pm Post subject: Kingfox tires |
I have only taxied my plane on wheels. The crowd over at the Avid site,
before I found this site, recommended 6psi for my tundra tires. They are
huge in comparison to the tires on your Arrow but are dwarfed by the King
Fox tires. They feel rock hard with as little as 8psi. I have been told
they are safe to fly with as little as 4psi. The important thing is both
tires have the same pressure.
Your tires would be considered low for a DC8 but just right for your Arrow.
Go to U-Tube and search "kitfoxflyer" you will see the advantages of the
tundra tires.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
ksridsdale(at)mipowerpara Guest
Posted: Sat Aug 11, 2007 3:27 am Post subject: Kingfox tires |
As the manufacturer the design (reccommended) pressure
for the King Fox tire is 8-10 PSI.
Kevin Ridsdale
MiPPi Ultralights
tundra tires.
Noel
Float Flyr
Posted: Sat Aug 11, 2007 7:58 am Post subject: Kingfox tires |
The tires I had on my plane for a very short time have Max 10psi marked on them. To avoid any confusion they are much smaller than the King Fox tires.
[img]cid:313033615(at)11082007-33B3[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
19.77 KB |
314 Time(s) |
Kitfox III-A
