Trio A/P Servo Mounting
sshook(at)cox.net
PostPosted: Mon Aug 13, 2007 2:45 pm    Post subject: Trio A/P Servo Mounting Reply with quote
I know I have asked this before and I put it off to work on other things…
There are some builders that have mounted their Trio Servo’s on the wing rib adjacent to the aileron belcrank, but those installations involved reinforcing the rib, etc. and I am not sure that is necessary or what I want to do.
Has anyone mounted the servo on the web of the wing spar in the bay next to the aileron belcrank? I can’t imagine that the four holes for some #6 screws and the eight #40 holes for the nutplates would weaken the structure any.
Thoughts anyone?
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
fstringham
PostPosted: Mon Aug 13, 2007 3:15 pm    Post subject: Trio A/P Servo Mounting Reply with quote
Scott
I placed the servo on the web of the rib as you have described but I did put
the servo on a .032 Al plate and used nut plates on the O/B side of the rib
to screw it to. Like you I thought the web would be suffiecient ....but my
motto throughout this project if I ever say "I THINK thids or that Might be
OK" then I would always cal Van"s, Check my favorite builder web sites, ask
the question as you have and ( time out of ten kicked it up a notch for
safety.
Frank (at) SGU RV7A wiring.....engine on the test stand.....prop with UPS
Reply-To: rv7-list(at)matronics.com
To: <rv7-list(at)matronics.com>
Subject: Trio A/P Servo Mounting Date: Mon, 13 Aug 2007 15:45:00
-0700
I know I have asked this before and I put it off to work on other things.
There are some builders that have mounted their Trio Servo's on the wing
rib
want
to do.
the aileron belcrank? I can't imagine that the four holes for some #6
any.
Thoughts anyone?
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
Learn.Laugh.Share. Reallivemoms is right place!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
rv6(at)earthlink.net
PostPosted: Mon Aug 13, 2007 3:39 pm    Post subject: Trio A/P Servo Mounting Reply with quote
I placed mine on the last rib of the wing,great for service.If ya need pic
I can send it to ya..
  John McMahon (RV6 180 CS)
andrew.phillips(at)sympat
PostPosted: Mon Aug 13, 2007 5:32 pm    Post subject: Trio A/P Servo Mounting Reply with quote
I ordered an install kit from safeair...made the install real easy!!!
John McMahon wrote:
[quote] Trio A/P Servo Mounting I placed mine on the last rib of the wing,great for service.If ya need pic
----- Original Message -----
To: rv7-list(at)matronics.com (rv7-list(at)matronics.com)
Sent: Monday, August 13, 2007 5:45 PM
Thoughts anyone?
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List
pablo(at)phonewave.net
PostPosted: Mon Aug 13, 2007 9:54 pm    Post subject: Trio A/P Servo Mounting Reply with quote
Contact John Morgensen at john(at)morgensen.com (john(at)morgensen.com) he took some pictures just before we closed his wing. His Trio is on the spar next to the tip, simple and neat + easily removable.---
bertrv6(at)gmail.com
PostPosted: Tue Aug 14, 2007 1:08 pm    Post subject: Trio A/P Servo Mounting Reply with quote
On 8/14/07, Paul Pflimlin <pablo(at)phonewave.net> wrote:
Contact John Morgensen at john(at)morgensen.com he took some pictures just
sshook(at)cox.net
PostPosted: Tue Aug 14, 2007 2:02 pm    Post subject: Trio A/P Servo Mounting Reply with quote
I have seen people mount other things on their wing spar web such as
terminal blocks, Adel clamps, etc. but I just want to be certain that I am
not going to compromise the spar strength by drilling four #6 holes and the
eight #40 holes for the nutplates.
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
