mountain4don
Posted: Tue Aug 28, 2007 6:41 pm Post subject: Firewall Engine Mounting Nuts |
I am working on the firewall and engine mounts through the firewall on my 601 XL, and found the plans call for AN 365-624 Self Locking nuts for the engine mounts on the firewall. These are the low temperature type with the plastic self-locking ring in them. I was wondering how they were holding up on the finished planes and if there was any trouble with them. Are they working loose at all? These are supposed to be limited to a 250 degree environment. And I am not sure the back of the engine won't produce heat in that range.
How many have switched these firewall engine mounting nuts to the High Temperature type AN 363-624 that look like castle nuts that have been pinched for the self locking feature? Or are people drilling the mounting bolts through the firewall and putting castle nuts and cotter pins through them to lock them on?
Don Mountain
_________________ Zenith 601XL, tail done, working on wings |
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Wed Aug 29, 2007 3:18 am Post subject: Firewall Engine Mounting Nuts |
Don
I had the same concerns when Ifirst saw the design, however, I decided to go
with the specified nuts. Also checked the factory plane and that is what
they used.
I have 145 hours on my 601 and nothing has loosened up. The areas where
these nuts are used does not see much heat
George May
601XL 912s 145hrs
Quote: | From: Don Mountain <mountain4don(at)yahoo.com>
Reply-To: zenith-list(at)matronics.com
To: Zenith <zenith-list(at)matronics.com>
Subject: Firewall Engine Mounting Nuts
Date: Tue, 28 Aug 2007 19:38:57 -0700 (PDT)
in that range.
Don Mountain
More photos, more messages, more storage—get 2GB with Windows Live Hotmail.
rstone4(at)hot.rr.com Guest
Posted: Wed Aug 29, 2007 4:09 am Post subject: Firewall Engine Mounting Nuts |
Don,
Why not just buy the required amount of all steel hot section lock nuts from Aircraft Spruce and use them. The cold section plastic nuts may do just as well but with all steel, you would have peace of mind.
Tracy Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
dredmoody(at)cox.net Guest
Posted: Wed Aug 29, 2007 5:50 am Post subject: Firewall Engine Mounting Nuts |
The first bit of useful info would be the the lack of any discussion following the actual observation of a problem. So, it probably hasn't been an issue on any of the flying 601XLs so far.
Second, given the cylinder head temps and the necessity for the ambient under cowl temperature to be significantly less, the air temp under the cowl should not be higher than 250 F. If it does get to that temperature very often or for very long periods, we'll probably have trouble with the fiberglass long before the bolts get loose.
If it feels more secure to you the AN 363-624 high heat, all metal style of locknut would not be an expensive add-on.
Reversing the bolt head to the forward side and the nut to the cockpit side is another option but likely to be pointless due to the thermal conduction of the bolt itself.
Dred
---- Don Mountain <mountain4don(at)yahoo.com> wrote:
Quote: | I am working on the firewall and engine mounts through the firewall on my 601 XL, and found the plans call for AN 365-624 Self Locking nuts for the engine mounts on the firewall. These are the low temperature type with the plastic self-locking ring in them. I was wondering how they were holding up on the finished planes and if there was any trouble with them. Are they working loose at all? These are supposed to be limited to a 250 degree environment. And I am not sure the back of the engine won't produce heat in that range.
Don Mountain
Posted: Wed Aug 29, 2007 6:26 am Post subject: Firewall Engine Mounting Nuts |
Don,
It's rather unlikely you'll see 225 degrees at the firewall mount bolts
unless you route your exhaust very near them. I used regular castle
nuts and drilled the bolts, but that leaves you with the necessity of
playing with washers to get the cotter hole to align at the torque you
want. I'd not recommend the pinched type castle nut because it will
damage the bolts in repeated removal and replacement. If you have
doubts with the low temp nuts, go with the standard castle type.
Don Mountain
tonyplane(at)bellsouth.ne Guest
Posted: Wed Aug 29, 2007 8:34 am Post subject: Firewall Engine Mounting Nuts |
I did not use the nylock nuts in the XL kit but instead used the hi-temp nuts supplied in the FWF kit from Jabiru USA. I torque-striped the nuts.
After checking the torque at 50 hrs, I have an annual requirement to check the torque on the nuts. I used 300 inch-lbs. I also check the torque whenever I remove the fwd top skin, which I installed to be removable.
As this area is probably subjected to cyclic loading, I would not recommend using castle nuts with cotter pins. I remember seeing pictures of a failure of one of the mount bolts a few years ago There was what appeared to be a lot of fretting corrosion in the area leading me to suspect loss of torque contributed to the failure.
Fair winds, VMC and CAVU to all
Tony Graziano
XL/Jab3300; N493TG; 280 hrs.
[b][i]Firewall Engine Mounting Nuts From: Don Mountain (mountain4don(at)yahoo.com ([email]mountain4don(at)yahoo.com?subject=Re:%20Firewall%20Engine%20Mounting%20Nuts&replyto=315099.3720.qm(at)web51310.mail.re2.yahoo.com[/email])) Date: [b]Tue Aug 28 - 7:41 PM[/b] Quote: | Quote: | I am working on the firewall and engine mounts through the firewall on my 601 XL,
Don Mountain
| [/i][/b] From: Don Mountain (mountain4don(at)yahoo.com ([email]mountain4don(at)yahoo.com?subject=Re:%20Firewall%20Engine%20Mounting%20Nuts&replyto=315099.3720.qm(at)web51310.mail.re2.yahoo.com[/email])) Date: [b]Tue Aug 28 - 7:41 PM[/b] [quote] Quote: | I am working on the firewall and engine mounts through the firewall on my 601 XL,
Don Mountain
| [b]
