Straight ribs
thomphy(at)msn.com
PostPosted: Fri Sep 07, 2007 6:14 am    Post subject: Straight ribs Reply with quote
Gary,
On my first kit, I made a jig out of scrap wood I found. I copied mine from
the one illustrated in one of the earlier RVater newsletters. This jig gets
all of your flanges square to the rib, then you flute to make them flat.
(Make sure you mark where your rivets are going so you don't have a flute
where the rivet goes). Find a picture of this tool and make it! You have to
do this to the wing ribs also. (The new kits come this way, YES!) Makes the
job easy and fast!
Anyone know which RVator it was in?
Thomas Phy
RV-7
Fuselage being worked on
Rotary powered
Greetings:
Have an '"older" empennage and instructions dating
back to 1999. Understand RV-7, 8 and 9 have the same
Vert Stabilizer. Is there anything in the "Newer
Instructions" about about tapering (angling) the
flanges of the VS Ribs to match the desired contour
(taper) of the VS ???
Thanks, Garey
