		Skykingjfg(at)aol.com Guest
				 Posted: Sun Feb 19, 2006 7:25 am    Post subject: Filter Air Box |
				I'm trying to install the FAB on my 7A. I have an XP 360 Carburetor engine. There doesn't seem to be enough clearance between the air box and the landing gear leg. In fact, if I just hold the filter element against the bottom plate there is only 1/2" gap between the element and the gear leg. This leg has got to flex a little when landing. I concerned that it will flex and hit the airbox. Anyone run into this and have a solution?
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		dan(at)rvproject.com Guest
				 Posted: Sun Feb 19, 2006 9:58 am    Post subject: Filter Air Box |
				Heat it up with a heat gun a press into it with a pipe.  It'll form a  "dent" (intentionally) that will provide clearance.  I don't have a  nosedragger, but that's what I'd try first.
  If that doesn't work, chop a hole into it where the nosegear leg  interferes, and re-glass it so it won't!  Get out the tools and make it  work!!!
  )_( Dan
  RV-7 N714D
 http://www.rvproject.com
  [quote]   ---
