jfrjr(at)adelphia.net Guest
carl.froehlich(at)cox.net Guest
Posted: Sun Sep 23, 2007 4:13 pm Post subject: engine baffling--paint? |
I used a dark gray, single stage Imron paint over PPG DP40LF primer for the baffles on my 8A. I used the same paint with a lighter gray Imron contrast color for the interior. This is a hard, durable paint. After 5 years it still looks brand new.
PPG Concept single stage paint is also a good choice. For the exterior I used PPG Concept clear/base coat. The product is very forgiving to the amateur painter.
Carl Froehlich
RV-8A (350 hrs)
RV-10 (wings)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jay Rowe
Sent: Sunday, September 23, 2007 7:45 PM
To: RV10-list(at)matronics.com
Subject: engine baffling--paint?
Just starting the engine baffling. Could/should I paint the baffling or just leave it as shiny alum? If painting is advised what do I use for paint, and what kind of prep works needs to be done on the alum? Thanks 10'ers. Jay Rowe
49 Bytes |
1984 Time(s) |
flysrv10(at)gmail.com Guest
Posted: Mon Sep 24, 2007 2:24 am Post subject: engine baffling--paint? |
I alodined the parts. It is easy to do and does not require much prep. I did the same on my RV6 and it showed absolutely no sign of corrosion after 13 years in Florida.
do not archive.
Rob
On Sep 23, 2007, at 7:44 PM, Jay Rowe wrote:
[quote]Just starting the engine baffling. Could/should I paint the baffling or just leave it as shiny alum? If painting is advised what do I use for paint, and what kind of prep works needs to be done on the alum? Thanks 10'ers. Jay Rowe
[img]http://promos.hotbar.com/promos/promodll.dll?GetPromo&El=&SG=&RAND=47770&partner=seekmo&/p.gif[/img]
