f.miles.tcp.833(at)clearw Guest
Posted: Mon Oct 01, 2007 9:13 am Post subject: Rotax 582 compressions |
Does anyone know what the normal compression range is for the Rotax 582? Second question; the engine manual speaks of decarboning the engine after so many hours, are the oil injected engines as prone to carbon as the engines with the fuel and oil mixed?
Frank Miles
Klll w/ 582
10/1/2007 10:20 AM
Guy Buchanan
Posted: Mon Oct 01, 2007 9:39 am Post subject: Rotax 582 compressions |
At 10:12 AM 10/1/2007, you wrote:
Quote: | Does anyone know what the normal compression range is for the Rotax 582? |
I couldn't find a recommendation. I get 118 to 125 psi, depending on the carbon load. I just use it as a relative number anyway.
Quote: | Second question; the engine manual speaks of decarboning the engine after so many hours, are the oil injected engines as prone to carbon as the engines with the fuel and oil mixed? |
I've never heard of a difference in all the literature I've read. Bob Robertson did, however, say that he no longer de-carbons at 50 hour intervals, waiting instead until the 150 hour rebuild. I also found http://www.decalinchemicals.com/DeeCarb.html which I'm thinking of trying. I spoke with the developer and he had no experience with 2-strokes, but suggested it should work. (I already use his Decalin lead scavenger in my 582.)
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
dave
Float Flyr
Posted: Mon Oct 01, 2007 12:37 pm Post subject: Rotax 582 compressions |
Those automotive compression testers are the most lying consarnd things ever created. Too many variables to have any accuracy, starting with the cranking speed. Differential is the only way to go only thing is if you hear air escaping it will be through the exhaust and the intake at the same time and the only thing it can be is the piston rings. try to keep the cylinders above 70/80.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
C260B(at)aol.com Guest
Posted: Mon Oct 01, 2007 1:39 pm Post subject: Rotax 582 compressions |
Hey everbody,
i have an almost new International 2si 460 F35 engine for sale. 3 hr TT. missing carb and exhaust. anybody interested? send me an offer.
shawn
c260b(at)aol.com
