wb2ssj(at)earthlink.net Guest
Posted: Fri Oct 05, 2007 3:16 pm Post subject: rudder cables |
Can anyone remember installing your rudder cables, you had a long and a short cable on each side. Does the long one or short one go up front? Where does the turn buckle end up? Tex
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
n1bzrich(at)aol.com Guest
Posted: Fri Oct 05, 2007 6:07 pm Post subject: rudder cables |
| Quote: | | Where does the turn buckle end up? | Tex, The turn buckle should end up under the baggage area so you can make the connection, adjust the tension, and then safety wire the turn buckles. On 31BZ that was about the middle of the space under the baggage area. Sorry, but don't remember if the longest one is in the back or front.
vettin74(at)yahoo.com Guest
Posted: Sat Oct 06, 2007 7:24 am Post subject: rudder cables |
The long cable is installed in the front and the short in the rear....Referance section 29 page 3 ..#32 for long cables ...and section 23 page 2 for short cables...
Nick...
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
