Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Sat Oct 13, 2007 3:44 am Post subject: New Kitfox Owner |
Hi Folks;
I've recently purchased a 90 % complete kitfox II which is finished to the point of painting (which I've started). The kit was built by one of my neighbours with superb workmanship. It literally came with everything (including paint) to finish to the point of test flying. I'll probably have numerous questions and this is the first.
The plane came with a new Rotax 582 with c box. I note that the engine attaches to its mounts with what I believe are 8mm bolts however the bolts which came with the kit are not AN and are not drilled for lockwires. Can anyone tell me what the normal practice for these bolts as I am not comfortable with lockwashers and locktite in this critical application.
Is there there a metric equivalent to AN??
Ken Potter
Lanark, Ontario.
henrysfork1(at)msn.com Guest
Posted: Sat Oct 13, 2007 4:42 am Post subject: New Kitfox Owner |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Ken my model II came with the AN bolts with lock nuts for the motor mounts.
Dee Young
Model II
Ken Potter
Posted: Sat Oct 13, 2007 5:01 am Post subject: Re: New Kitfox Owner |
The bolts which attache the mounts to the rails are drilled AN with nuts and pins. The bolts which go from the mount however into the blind holes on the engine are the ones I am describing.
Cheers
Ken
Posted: Sat Oct 13, 2007 5:12 am Post subject: New Kitfox Owner |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Sorry, don't have the 582
Guy Buchanan
Posted: Sat Oct 13, 2007 5:32 am Post subject: New Kitfox Owner |
At 04:44 AM 10/13/2007, you wrote:
| Quote: | Can anyone tell me what the normal practice for these bolts as I am
I'm guessing you're talking about the "side mount" versus the "bottom
mount" that uses the four big studs coming out of the bottom of the
case. I'm also guessing you're talking about the fairly short bolts
holding the four individual "T's" onto the case. These T's have lord
mounts that sit on the side rails of the engine mount, right?
I can't tell you what "normal practice" is but I run with lock
washers and Loctite, and have not had a problem. Note, however, I'm
doing that only because I DIDN'T THINK OF IT. < Now that you
mention it, I'll pull the bolts and drill and safety wire them.
There are metric aircraft bolts, NA series, but a class 8.8 bolt has
equivalent strength and is probably what you've been provided. (It's
stamped 8.8 on the head.) A quick Google didn't reveal any obvious
sources for metric aircraft fasteners or drilled heads, but I did
find www.metricsunlimited.com which seemed to have nearly every
metric fastener known to man. Also, CPS (California Power Systems,
www.800-airwolf.com) sells drilled head M8's for prop bolts. They may
have a source, or may drill themselves.
Let us know if you find a source for NA series bolts or drilled metrics.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
dave
Posted: Sat Oct 13, 2007 7:02 am Post subject: Re: New Kitfox Owner |
Ken, I am Near London Ontario.
drop me a email dave (AT) cfisher.com
with your Phone number And i will call you up.
The early Kitfoxes used the rotax studs on bottom of crankcase to the engine plate. Whereas the IV used the side mount with lord mounts which I have in stock.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
