Mod 74 Again
Troy Maynor
PostPosted: Wed Oct 17, 2007 7:12 pm    Post subject: Mod 74 Again Reply with quote
Hi All,
I have received my Mods 52 and 74. Reading over # 74 a question comes to
mind. Can anyone tell me why I was under the impression the new rear wing
pin was going to be threaded through the flap attaching point, then a nut,
within the wing. Was this an early speculation of a possible fix? I plan to
start the socket and tie bar portion of mod 52 before getting into the wing.
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Paint,(some) interior,engine install, (some) wiring.
Weaverville, NC USA
winmail.dat
 Filename:  winmail.dat
 Filesize:  1.8 KB
 Downloaded:  735 Time(s)
ptag.dev(at)tiscali.co.uk
PostPosted: Wed Oct 17, 2007 10:40 pm    Post subject: Mod 74 Again Reply with quote
Hi! Troy
There is a mod. Variant which allows access through the flap close out. I requested it be considered but was “knocked back “ …now having invaded mine the variant has been produced. However you need to clearly establish that the threaded hole is absolutely central to the sandwich stack (including the edge of the flap hinge bracket to be “eyed” up also in line with the edge of the same stack since the threaded hole also goes through it. To remedy any deficiency with these items would IMHO be very difficult through the flap close out.
Bob Harrison G-PTAG . [list][list]
