Stall warning location
plevenda@jvlv.lv
PostPosted: Wed Oct 24, 2007 4:06 pm    Post subject: Stall warning location Reply with quote
Well, count one for "candle moth syndrome". I pulled out my first quickbuild wing yesterday, which was the right wing. I set it on the table, removed the bottom skin and went to work. In the process, as I got around to the leading edge, I noticed the two pre-drilled holes for the stall warning vane. So I flipped to the page in the manual and went to work cutting out an access hole and the slot for the vane. Only AFTER I had all that done did I remember I was working on the right wing. It was also then that I noticed that Van's pre-driled holes for the stall warning on BOTH wings. Oh and yes there is a caution note in the manual, but like I said, "Candle Moth"
In all my years of flying I was never given a reason why the stall warning is traditionaly on the left wing. So now do I accept an extra access hole, patch up the slot on the right wing and start all over again on the left wing, or is there any reason why the stall warning would not still work on the right wing even though it is not in the traditional location.
Paul Levenda
#40090
N974LV
coop85(at)cableone.net
PostPosted: Wed Oct 24, 2007 4:41 pm    Post subject: Stall warning location Reply with quote
Paul,
Of course the safe answer is to ask Vans about it. However since the
airplane stalls so wonderfully benign and level I can't help but think the
AOA is the same on both sides at the same point so shouldn't matter which
side the sensor is on.
My unscientific opinion,
Marcus
40286
Tim Olson
PostPosted: Wed Oct 24, 2007 4:59 pm    Post subject: Stall warning location Reply with quote
I'm not sure that it would make any difference at all, but if I were
in your shoes, I'd probably feel just like you do. And, if I were
feeling that way, I'd probably proseal in a patch on the inside of
that slot, and then use filler to fill the slot back up and make it
smooth again. Then I'd put the slot in the other intended wing.
No big deal.
plevenda(at)jvlv.lv wrote:
<paulevenda(at)mac.com>
-------- Paul Levenda #40090 N974LV
http://forums.matronics.com/viewtopic.php?p=141602#141602
dav1111(at)suddenlink.net
PostPosted: Thu Oct 25, 2007 5:44 am    Post subject: Stall warning location Reply with quote
I agree with Tim's suggestion on closing up the wrong wing, however if I had it to do over again I WOULD NOT install the stall warning at all.
Russ Daves
N710RV - 175+ hours and having a ball.
Time: 05:59:21 PM PST US From: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> Subject: Re: Stall warning location
No big deal.
plevenda(at)jvlv.lv (plevenda(at)jvlv.lv) wrote:
> <paulevenda(at)mac.com (paulevenda(at)mac.com)>
johngoodman
PostPosted: Thu Oct 25, 2007 6:53 am    Post subject: Re: Stall warning location Reply with quote
Paul,
I wouldn't worry about it. The only reason that I know of for the stall warning being in the left wing is because of left hand patterns when landing. I'm not installing the Van's stall warning, I'm going with AOA.
av8or(at)cox.net
PostPosted: Fri Oct 26, 2007 8:08 am    Post subject: Stall warning location Reply with quote
The reason I was told it's on the left side is because the usual traffic pattern is to the left. The left wing goes slower in a left turn than a right so the airspeed on that wing in that critical phase of flight would be the lowest. This would warn of the stall on that wing which would occur before the right wing resulting in the stall/spin.
John Lenhardt
#40262
pitts_pilot(at)bellsouth.
PostPosted: Fri Oct 26, 2007 12:23 pm    Post subject: Stall warning location Reply with quote
My Certified Grumman ...... has the stall warning switch on the right wing ..... as seen from the pilot seat. However, you do have a valid point. I'm not going to have a stall switch ..... or an AOA ....... I'm just going to use all the info the airplane naturally gives you. If you ignore all those natural hints .... you'll probably ignore the stall warning horn too!
Linn
John Lenhardt wrote:
[quote] The reason I was told it's on the left side is because the usual traffic pattern is to the left. The left wing goes slower in a left turn than a right so the airspeed on that wing in that critical phase of flight would be the lowest. This would warn of the stall on that wing which would occur before the right wing resulting in the stall/spin.
John Lenhardt
#40262
----- Original Message -----
Sent: Wednesday, October 24, 2007 8:06 PM
Subject: Stall warning location
--> RV10-List message posted by: "plevenda(at)jvlv.lv (plevenda(at)jvlv.lv)" <paulevenda(at)mac.com (paulevenda(at)mac.com)>
Paul Levenda
#40090
N974LV
