dredmoody(at)cox.net Guest
Posted: Mon Oct 29, 2007 7:57 am Post subject: VDO sender installation instructions for the LE tanks on an |
I don't know much about the HD and HDS but I believe their airfoil is very different from a 601XL. Given that difference, is the shape of the wing tank different as well? If the shape of the tank is different the bend pattern recommended for a 601XL tank sensor arm might be very different from the pattern recommended for an HD or an HDS. It might be a good idea to call the factory and get the pattern or the missing assembly guide page file sent out.
It's just a thought,
Dred
Gig Giacona
Posted: Mon Oct 29, 2007 8:24 am Post subject: Re: VDO sender installation instructions for the LE tanks o |
The VDO sender comes with a set of instructions that are not aircraft specific. The table takes in several dimensions of the tank.
601XL Under Construction
jeffrey_davidson(at)earth Guest
Posted: Mon Oct 29, 2007 4:29 pm Post subject: VDO sender installation instructions for the LE tanks on an |
Dred,
You are right. The leading edge tank for the HD has a much
different profile. The HD wing has a constant (Hershey bar) chord. It
doesn't taper like the HDS and it is much thicker than the XL. It does give
a lower stall speed without flaps. And a different VDO sender is used. So
the XL pdf is generally helpful, but the bending instructions are very
different.
Jeff D
different from a 601XL. <snip>
Dred
