txpilot
Posted: Sat Nov 03, 2007 11:31 pm Post subject: Questions on Z-16 Diagram |
Hello,
I'm currently building a Zenith CH-701 with a Rotax 912S. I'm using the Z-16 revision M schematic as a guide for designing my electrical system. I'm afraid I'm struggling a bit on understanding this diagram and have a few questions.
1. The schematic shows the start switch connected to a starter contactor which I assume would be B&C part S702-1. I'm using an ACS A-510-2 ignition switch. Can this start switch be directly connected to the starter relay supplied by Rotax, or will I need to purchase S702-1 and run it in series with the supplied starter relay? Do I need to worry about excessive wear on the start switch contacts if I directly connect the start switch to the Rotax starter relay?
2. I'm trying to understand the overvoltage protection. Correct me if I'm wrong, but I believe this is the sequence if the voltage regulator fails:
A. Crowbar Overvoltage Module senses the overvoltage condition. Creates a 'short' from alternator master switch to ground.
B. Alt breaker responds to the short by tripping, thus de-energizing alternator OV disconnect relay.
C. Alternator OV relay opens circuit from alternator (yellow AC wires), thus removing the alternator from the system.
3. Assuming I'm right on number 2, I'm confused on the N.C. and N.O. terminology. I thought an energized relay circuit would be considered 'normally closed', but according to the diagram that would open the circuit and take the alternator off line. I don't mean to get too wrapped up on the terminology, but I want to make sure I understand what I'm doing here.
Thanks in advance for any advice.
Best Regards,
Dan Ginty
Posted: Sun Nov 04, 2007 4:23 am Post subject: Questions on Z-16 Diagram |
txpilot a écrit :
Dan,
I wired two airplanes using Fig Z16 with no problem.
Quote: | 1. Can this start switch be directly connected to the starter relay supplied by Rotax,
You can use the Rotax starter relay. Make sure to add a diode or else
across the coil.
Quote: | 3. Assuming I'm right on number 2, I'm confused on the N.C. and N.O. terminology. I thought an energized relay circuit would be considered 'normally closed'
Most relays have 'normally open' and 'normally closed' contacts. That
tells us which contacts are closed or open when *de-energized*. You
chose which set of contact you want to use.
You may wish to look at the relay documentation to identify which
contacts are which, otherwise you can use a multimeter.
Best regards,
Gilles
http://contrails.free.fr
Bob McC
Posted: Sun Nov 04, 2007 8:34 am Post subject: Questions on Z-16 Diagram |
Dan;
"Normal" with respect to switch or relay contacts means just that, "normal", "most of the time", "as sitting on the shelf" , etc. The opposite of "normal" is the activated or energised state where power is applied to the relay coil, the switch is activated, etc and the contacts transfer to the opposite position.
Bob McC
[b]---
_________________ Bob McC
Falco #908
(just starting) |
txpilot
Posted: Mon Nov 05, 2007 12:10 pm Post subject: Re: Questions on Z-16 Diagram |
OK. That makes sense. Thanks for clarifying it.
Two other questions come to mind: is the CB really necessary if there's also a fuse in series? After reading the Aeroelectric Connection, Bob has me sold on fuses and I didn't plan on adding any breakers to my panel.
Second, regarding E-bus Alternate feed switch, is it a good idea to make that a guarded switch? I would hate for that switch to be accidentally left on overnight and thus draining the battery.
Dan Ginty
nuckolls.bob(at)cox.net Guest
Posted: Mon Nov 05, 2007 5:39 pm Post subject: Questions on Z-16 Diagram |
I presume you're speaking of the alternator control
feeder to a breaker that is upstream of a crowbar
ov protection module. There's a fusible link which is
not really a fuse but a concession to traditional
notion in the T/C aircraft world for "protecting"
longer than 6". If you use some other ov protection
scheme, you could leave the breaker out and just
run the alternator field from a standard fuse
on the block. One choice would be using the AEC9011
generator/alternator OV relay feature. This
eliminates the need for a breaker.
It's not practical to use a fuse upstream
of a breaker . . . crow-barring a 5A breaker
will pop a 20A fuse, hence the fusible link
with a very robust I-squared*T fusing constant
in comparison with the breaker.
Quote: | Second, regarding E-bus Alternate feed switch, is it a good idea to make
Have your low oil pressure warning light run
from the e-bus . . . or buzzer. If the engine
is not running and the e-bus is up, it notifies
you. But then, one can use guards on any switch
in the airplane. Are there not things on the
e-bus that would stay lit-up as sufficient
warning? My personal preference is making it
a checklist item. Except for pre-flighting the
e-bus alternate feed switch, there's no reason
to turn it on except in case of alternator
failure . . . hence probability of accidental
failure to turn off at end of flight is
considerably reduced.
vozzen
Posted: Mon Nov 05, 2007 8:14 pm Post subject: Re: Questions on Z-16 Diagram |
Along these same Z-16 lines (Jabiru/Rotax with 20 amp AC generator)...
Is it any problem for the regulator if it's control ("sense") is fed from the same circuit breaker as the OV module ( and OV-relay coil)?
In other words, if the OV relay trips (breaking the AC line between the alternator and regulator), the "sense" line to the regulator opens, dropping the control voltage into the regulator to zero. Is this a problem?
Would there be any advantage (or disadvantage) to feeding the regulator control directly from the bus?
Thanks in advance.
Richard, 601XL/3300
txpilot
Posted: Tue Nov 06, 2007 7:55 pm Post subject: Questions on Z-16 Diagram |
Depending on who's rectifier/regulator is being
used, there may be manufacturer's prohibitions
for connection of "C" to the bus independently
of B and R. Having said that, and based on what
I've seen of what's reputed to be an exemplar
schematic of this genre' of rectifier/regulator,
(See: http://www.aeroelectric.com/Pictures/Regulators/regul_912.jpg)
I can perceive no reason in the physics for
this prohibition. But unless provided with
a lucid schematic of the specific device
in question, I cannot refute the prohibition
with confidence. Hence the drawing you see
in Z-16.
What problems have you deduced for wiring
as suggested?
( "Problems are the price of progress. )
( Don't bring me anything but trouble. )
( Good news weakens me." )
( -Charles F. Kettering- )
vozzen
Posted: Wed Nov 07, 2007 1:15 pm Post subject: Re: Questions on Z-16 Diagram |
as suggested?
None-- looks great. I was using the outdated Rev.K, which showed C-lead coming thru the OV trip breaker circuit, instead of direct from battery (via Master Sw).
Thanks, Bob, for your continuing attention.
Posted: Wed Nov 07, 2007 4:14 pm Post subject: Questions on Z-16 Diagram |
At 01:15 PM 11/7/2007 -0800, you wrote:
as suggested?
(via Master Sw).
No problem . . . and I wasn't trying to challenge you
on the 'modification' . . . I'm just trying to be
sensitive to errors in my perceptions and
evolution in new products.
