Malcolmbru(at)aol.com Guest
Posted: Mon Nov 05, 2007 7:05 pm Post subject: cross wind technique was scuffed wing tip |
someone suggested a cross control technique. any ideas on that?
malcolm mi 582 totally completed by the guy I bought it from.
akflyer
Posted: Mon Nov 05, 2007 8:39 pm Post subject: Re: cross wind technique was scuffed wing tip |
when landing in a cross wind you should have your up wind wing banked to the wind and use opposite rudder to keep the nose pointed straight down the runway. If the wind in coming from the right side, you will be right wing low and left rudder. Same with takeoff. you would hold full right aileron then as speed builds and you get light on the gear start relaxing the right till you have just enough in to keep the right wing slightly low. As soon as a climb is established, let the nose weather vane and set up a crab that keeps you on the centerline of the runway on climb out.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
