		hgmckay
				 Posted: Thu Nov 08, 2007 8:09 am    Post subject: Overload Clutch |
				I have a 912 UL (non-certified) engine S/N 4406269 in my Allegro 2000. In reading the Rotax Operator’s Manual there are four “configurations” of this engine. Configurations 1, 2, 3, and 4. Configuration is no longer available and was replaced by configuration 2. So there are actually only three configurations as noted in the manual, 2, 3, and 4. From the descriptions of configurations 3 and 4 they are for engines with constant speed propellers that have hydraulic governors. Therefore, this leaves only one configuration for those of us with “fixed” pitch props; configuration 2. The manual further states that the gearbox overload clutch is only installed on 912 UL (non-certified) engines that are of configuration 3. Therefore we who have 912 UL engines with fixed pitch props do not have the overload clutch in our engines. Am I correct in this conclusion?
 Hugh McKay
 Allegro 2000
 Rotax 912 UL
 N661WW
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		docyukon(at)ptcnet.net Guest
				 Posted: Thu Nov 08, 2007 9:23 am    Post subject: Overload Clutch |
				Hugh          Check the  part# stamped on top of the gear box.    # 996605 will not  have a factory installed clutch.  # 887280 will have a factory  installed clutch.  If you have neither of these #s call Lockwood with the  six digit # you have. they will be able to tell you exactly what is inside your  gear box.       Bill S.
  [quote]   ---
				 Posted: Thu Nov 08, 2007 9:53 am    Post subject: Overload Clutch |
				Hi! Hugh
 I have a 914 which is the turbo version. However I had to order the slip clutch and heavy duty starter on the options list when the engine was ordered.
 I may say the engine starts with one single dab on the start button, none of the rocking and shuddering I’ve noticed with others. Similarly on shut down it is a complete none event. Of course the slipper clutch if set right is a crank shaft protector in the event of prop strike.
 Bob Harrison Europa MKI (previously with Jabiru 3300 six cylinder and enjoying comparison ! G-PTAG
		Thom Riddle
				 Posted: Fri Nov 09, 2007 5:51 am    Post subject: Overload Clutch |
				Hugh,
 I know that the 912UL standard engines does NOT have the "slipper/
 overload clutch" and a 2.273:1 reduction ratio. The 912ULS comes
 standard with the clutch and 2.43:1 reduction gear set. Both the
 clutch and 2.43:1 gear set are options for the 912UL independently of
 each other.
 Thom in Buffalo
 Allegro 2000 w/ 912UL
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
