Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Wed Nov 14, 2007 8:52 pm Post subject: Z19RB question |
Bob,
I am using your Z19RB architecture in my RV7 with Eggenfellner Subaru E6T.
With the dual batteries and battery contactors in the rear of the plane and
a single "fat wire" coming forward do you see any problem with putting a bus
bar (like Stein's BB235: http://www.steinair.com/images/store/bb2305.jpg)
near the firewall to terminate the fat wire?
I would continue the fat wire from this bus bar to the starter contactor on
the engine. The feed for the "Main Power Distribution Bus" would come from
this bus rather than the starter contactor as depicted on Z19RB. This way I
can do all the wiring (and testing) behind the firewall without having the
engine mounted. I can see that I have created one more joint in the run
from the batteries to the starter contactor but is that really a problem?
Also, I have a pair of Gigavac GX11 contactors for the battery contactors
and I was wondering how best to connect the coil ground wire (and optional
NO/NC/COM contact wires if I choose) to the wires carrying them to the
instrument panel mounted switch? Possible choices include:
AMP "Mate-n-Lock" / Molex
Mount a terminal strip with faston tabs by each contactor
AMP Knife Splice?
Allen Fulmer
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
nuckolls.bob(at)cox.net Guest
Posted: Fri Nov 16, 2007 10:58 am Post subject: Z19RB question |
At 10:51 PM 11/14/2007 -0600, you wrote:
Bob,
AMP Knife Splice?
My personal choice would be knife splices but either
of the other two technologies would probably be okay
if installed with good craftsmanship. My personal
design goals call for lowest parts count and minimized
process requirements. Knife splices and heat shrink
are the most attractive solutions to those goals.
( -Thomas Paine 1776- )
longg(at)pjm.com Guest
Posted: Fri Nov 16, 2007 5:26 pm Post subject: Z19RB question |
Bob,
Re: the Eggenfellner installation and Z19. Eggenfellner recommends a 200
amp ANL fuse close to the positive battery post on each battery. I don't
see this reflected in your design, so in your opinion is this justified
or just an uber precaution?
Allen Fulmer
Posted: Fri Nov 16, 2007 6:35 pm Post subject: Z19RB question |
Thanks Bob,
Any thoughts on the first question?
| Quote: | >>> I am using your Z19RB architecture in my RV7 with
>>> of the plane and
>> with putting a bus
>> would come from
>> Z19RB. This way I
>> without having the
>> joint in the run
>> really a problem?
N808AF reserved
