herbgh
Posted: Sun Nov 18, 2007 12:23 am Post subject: Big Twin 4 stroke? Mil surplus |
125 to 130 lbs fairly well stripped,aluminum prop hub, over 40 horses..
220+ lbs of static thrust.. 084 mil surplus engine..
A friend of mines numbers.. I sold him the engine for 250 and he zero
timed it for less than 200 more..Looks promising..
A full VW with 69 mm crank and 94 jugs would weigh a bit more
,stripped, one mag, and put out much more thrust .. Cheap to build and
maintain too..
However..my Global with 78.5 stroke and 92 jugs is 84 lbs and puts out
35 to 37 hp. Herb
On Sun, 18 Nov 2007 00:02:24 -0600 "Richard Girard" <jindoguy(at)gmail.com>
writes:
At the weight you're quoting for the big twin, which is entirely in
line with the weights listed for the Vanguard and Honda V Twin
industrial engines, the Continental A084 becomes real attractive.
They
can still be had for under $1000 and you get the designed in
balance
of the flat 4.
Rick
