		Gilles.Thesee(at)ac-greno Guest
				 Posted: Sun Nov 18, 2007 9:13 am    Post subject: Re : RE: Re : Re: Rectifier-Regulator |
				Output of the Rotax internal generator is 18A.  80% of that is
  	  | Quote: | 	 		   14.4A.  That
  is the greatest load I expect you would want to put on your buss
  and still
  have a margin of safety.
 Noel,
 Experience from the field and from the lab seems to indicate that 12 A permanent load is the most one should expect from the Rotax Ducati regulator to avoid overheating and self-destruction.
 So we'd better keep the loads to a minimum.
 Best regards,
 Gilles
 http://contrails.free.fr
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Float Flyr
				 Posted: Sun Nov 18, 2007 9:49 am    Post subject: Re : RE: Re : Re: Rectifier-Regulator |
				In this case I agree....   Go with the experience and limit the load to 12A
 maximum.  If you need more capacity than that, install a larger alternator.
 2A (at) 12V may not seem to be very much....  Until you see how that can burn a
 wire.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
