rikvincent(at)aol.com Guest
Posted: Mon Nov 19, 2007 4:42 pm Post subject: O-360 A1-G6 on a -6 or -7?? |
Mine is a B1E which is also a rear draft. I changed the sump to a down draft so I could use all the standard stuff, air intake cable mounts ect.
| - The Matronics RV7-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
Posted: Mon Nov 19, 2007 6:12 pm Post subject: O-360 A1-G6 on a -6 or -7?? |
I don't have my finish kit yet. Do you know if the motor mount tube that
ties the tops of the two gear towers (-7 tail dragger) interferes with
the carb?I talked to Van's tech help today & they said no problem on
dishing the lower firewall between the angles, but they didn't say
whether the mount cross-tube would hit the carb in its stock position.
Assuming that I change the sump & intake tubes, will I have to change
the oil pickup tube also?
rikvincent(at)aol.com wrote:
[quote] Mine is a B1E which is also a rear draft. I changed the sump to a down
Posted: Mon Nov 19, 2007 6:23 pm Post subject: O-360 A1-G6 on a -6 or -7?? |
the sump is the same size it didnt interfear with the pickup
