		rlborger(at)mac.com Guest
				 Posted: Tue Nov 20, 2007 5:52 am    Post subject: Fwd: RE: Rotax Oil Filter Question |
				Hugh & the rest of the Rotax crowd,
 Here's the reply from Dean, the instructor at Lockwood Aviation along with the question I posed.
 FWIW, I also have done like Thom and ordered my oil filters in batches to minimize the shipping costs and amortize it over a number of filters.
 Check six,
 Bob Borger
 [quote]From: "Dean Vogel"
 To: "'rlborger'" <rlborger(at)mac.com>
 Date: November 20, 2007 07:34:12 AM CST
 Subject: RE: Rotax Oil Filter Question
 No I can't, the one thing I know is that the pressure is about 25% higher on
 the Rotax filter than on the normal automotive filter.  So if you need to be
 at 120F oil temperature before you can be sure the Rotax filter is running
 filtered oil through the system, what temperature do you have to be at with
 the automotive filters?
 Thanks for helping to keep people safe.
 Dean
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue Nov 20, 2007 2:06 pm    Post subject: Fwd: RE: Rotax Oil Filter Question |
				Curious question.
 I plan on using Rotax oil filters, this way if there is ever a change or
 recall, I am not the one to find out.
 The curious question is what exactly is the problem with sending
 unfiltered oil through your engine? There is a screen in the oil tank?
 I owned a 1948 Cessna 170 with a C-145 (just bout same as O-300) for 19
 years, and it didn't have an oil filter, just a "snake catcher" with holes
 like 1/8". Never had a failure, and we majored motor within first few
 years, no major wear or damage, and today the new owner is 3/4 the way to
 major again with no major troubles.
 I have heard also that the screen in the oil tank gets clogged especial
 when using 100LL, but that happens with a Rotax filter?? This should be a
 reasonable snake catcher?
 I also own 2 1957 BMW Isettas, they have no oil filters either.
 (Is it debris that will trash oil pump? Debris that will clog oil passages
 (where)? Debris that will collapse lifters? Just curious, I would think
 that Rotax would have sized the screen mesh in oil tank to prevent?
 I also own 3 early 90s Volvo turbo wagons. It just so happens Volvo uses
 Mann as Mfg for their filters. Early on I sawed opened Volvo and other
 filters, Mann was far superior to others but felt the same and looked the
 same. The bypass on some were poor at best. I only use Mann filters
 purchased by the dozen.
 I read very careful, and looked in detail at my 1983 Volvo turbo wagon
 that used Garette air cooled turbo that is very close to 914 Rotax. I know
 I am going to get flamed on this one, but my findings were it is in your
 best interest to fill to top the oil filter before you install it! Many
 who have never tried it think the entire contents will come pouring out.
 "NOT". Slight bit of finesse and you will not spill a drop. Uncoordinated
 and only a few drops. That will be on top of the many drops that happened
 when unscrewing filter, unless you made hole and drained first. It is
 surprising just how long it takes to fill filter completely full, it keeps
 on absorbing. For a neat freak in an imposable cowled aeroplane, where
 every drop is a problem, fill filter and freeze it, install quick with no
 drops.
 Ron Parigoris
		rampil
				 Posted: Wed Nov 21, 2007 9:46 am    Post subject: Re: Fwd: RE: Rotax Oil Filter Question |
				Ron,
 Recall for a moment that Issettas are not a good model of the Rotax
 9xx.
 Recall that that the Rotax has tiny oil galleries all over for cooling
 The Rotax has hydraulic lifters with tiny oil channels
 The Rotax cylinder heads are tempered aluminum alloy which will
 soften dramatically if overheated.  Clogged channels hurt engine,
 just like at all the precautions against air bubbles in the galleries!
 There are other reasons as well.
 I am sure you will not unfilter your nice unflown 914 when the time comes,
 so it doesn't seem reasonable to frame your question in such a way as
 to suggest it to others,
