Kellym
Posted: Sat Nov 24, 2007 8:52 pm Post subject: [Suspect] Re: Removing Ethanol from your car-gas? |
What is being talked about is referred to as phase separation. With
ethanol it takes at least an equal amount of water to the ethanol, and
very cold temps to get the ethanol water mix to settle out. Try putting
some beer in mogas and see how well it settles out. Beer is usually 5-6%
ethanol, the rest water. It might work.
Ethanol in gasoline is 10% pure anhydrous ethanol.Good luck on
separation, and better luck at getting all that contaminated water out
of your tanks.
Also consider that mogas, even without ethanol is very hard on the PRC
sealant in your tanks. Tends to soften the sealant too much, leading to
leaks. I know of a Mooney owner that flew with mogas on the sly. No
issue with the engine, but his tanks turned to much and he had to put in
bladders to fix it.
c.ennis wrote:
The EAA sells an ethanol tester....works exactly as you say. It is
graduated and gives you the percentage of ethanal contained in a given
volumn of fuel. Around here (northern KY area) it runs in the
neighborhood of 10 to 12 percent, that was 2 months ago. If auto fuel
were at $3 a gallon that would be around 30 cents out of every gallon
bought which would be unusable and disposed of. I guess you could dump
it in your car if you could separate it from the water.
It seems to me that avgas is better for your engine, you don't have to
spend any time fussing with it to remove ethanal, you don't have to
haul it to the airport in 5 gallon cans, you don't have to get rid of
the unusable portion of it and you don't have to wonder and worry
about what it may be doing to that expensive prop crank on the front
of your airplane.
As an added thought, what kind of container do you use to "settle" out
the ethanal? Something would need to be built which would hold a
minimum of 20 gallons or so, or it would take hours to "unrefine"
enough to be useful, in 5 gallon batches ( you only get 4 1/2 gallons
usable out of every 5 you buy).
Of course, thats just my opinion.
Charlie Ennis
KCHD |
acepilot(at)bloomer.net Guest
Posted: Sat Nov 24, 2007 9:09 pm Post subject: [Suspect] Re: Removing Ethanol from your car-gas? |
Maybe I'm missing something (and I'm NOT a chemist) but I think the
original poster was saying that if you mixed water in a tank (NOT the
aircraft fuel tank!!) of gas with ethanol in it, the ethanol would
"attach" itself to the water. We all know that water settles to the
bottom of a tank of gas. If a drain (petcock) was fitted to the mixing
tank, one could drain off the water that now has the ethanol attached to
it, removing the ethanol and leaving the gas only in the mixing tank.
One could probably then distill the ethanol out of the water to reclaim
a portion of it to be used in the tractor or lawn mower if desired.
Feasible? (I've sent the original post to a chemist in our EAA chapter
to see what he thinks)
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Kelly McMullen wrote:
putting some beer in mogas and see how well it settles out. Beer is
usually 5-6% ethanol, the rest water. It might work.
of your tanks.
to leaks. I know of a Mooney owner that flew with mogas on the sly. No
in bladders to fix it.
> given volumn of fuel. Around here (northern KY area) it runs in the
> dump it in your car if you could separate it from the water.
> to spend any time fussing with it to remove ethanal, you don't have
> to haul it to the airport in 5 gallon cans, you don't have to get rid
> of the unusable portion of it and you don't have to wonder and worry
> of your airplane.
> out the ethanal? Something would need to be built which would hold a
> Charlie Ennis
> do not archive
ronlee(at)pcisys.net Guest
Posted: Sun Nov 25, 2007 7:08 am Post subject: [Suspect] Re: Removing Ethanol from your car-gas? |
Better to never put ethanol in fuel in the first place. It is a major scam
being foced on the American public. Plus it raises food prices that
depend upon corn.
Ron Lee
