chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Thu Nov 29, 2007 5:47 am Post subject: XL baggage compartment fan |
Hi
I have read that some people have put a fan into the baggage back bulkhead (6B12-2) of their XL's.
What type of fan and does it work well? I was thinking of a 12v computer
power supply fan of about 4 ". In our Hot Aussie summers I think I will need something during taxi. ram air should work once airborne.
Anyone got any Ideas or done something similar?
Chris
dredmoody(at)cox.net Guest
Posted: Thu Nov 29, 2007 7:05 am Post subject: XL baggage compartment fan |
I have installed two cpu type muffin fans in my Zodiac XL. The bad news is that it isn't finished so I don't yet know how well they will work. Here's what I do know;
They are available in lots of sizes and standard cubic feet per minute (scfm) capacities.
I put a 4" 35 scfm model in the aft baggage bulkhead of my plane. My purpose was not to keep us cool under the bubble canopy on the ground. I really don't think it will move enough air to make a significant difference in that situation. What I think it will do is moveenough air while parke doout in the sun at a fly-in to keep the cockpit from becoming a broiler. Ata destination airport, I would use a canopy cover to reflect most of the sun's energy, but at a fly-in it will sit there like a greenhouse so the few hours of minor electrical drain may prove useful. I'll find out later but right now it's a guess.
What I will use during taxi is a custom made strut to support the canopy in an open position until run-up and take-off.
The second fan is under the C-channel from the bottom center of the panel to the firewall stiffener. I mounted it there to cool the avionics which would otherwise sit in an upside down bowl of captured heat under the forward top skin. I may decide later on to drill some vent holes in that forward top skin just inside the canopy to use that avionics heat to defrost the front of the canopy if I see the need.
Dred
Jaybannist(at)cs.com Guest
Posted: Thu Nov 29, 2007 8:34 am Post subject: XL baggage compartment fan |
Ed, I put one of those little computer fans in the top forward skin, just to move a little air behind the panel and maybe do a light canopy defogging. Like yours, it is not battle-tested.
Jay in Dallas 601XL N2630J
Dred
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Thu Nov 29, 2007 9:52 am Post subject: XL baggage compartment fan |
I have also been pondering the problem of keeping the cockpit cool when the
plane is parked in the sun. My flight instructor always put a reflective
sun screen in his C-150's windshield when it was parked in the sun. For
years I've used, in my cars, the reflective screens that are made of thin
blister packing material sandwiched between foil. These work amazingly
well. I'm thinking of buying the largest one I can find for a car, cutting
it to fit the outline of the canopy-fuselage seal, and using sticky Velcro
to hold it in place. I might need to cut it into 2 sections for easy
storage. The extra large one we have in our car weighs 13 oz.
Has anyone tried this approach with a 601? It seems a lot simpler than a
fan or a canopy cover.
Terry
At 10:04 AM 11/29/2007 -0500, you wrote:
Quote: | I have installed two cpu type muffin fans in my Zodiac XL. The bad news is
what I do know;
(scfm) capacities.
Dred
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 slow build kit - Rudder done--finally; working on the stab
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Mainwheels
Posted: Thu Nov 29, 2007 10:09 am Post subject: XL baggage compartment fan |
Hi Chris;
Computer fans work very well in this application. You might even
consider using 2 of them. I have only one at present. On really hot days
, more air is welcome.
CH-601HDS 1400 hrs.
chris Sinfield wrote:
Quote: |
Hi
Chris
http://forums.matronics.com/viewtopic.php?p=149338#149338
dougsnash(at)yahoo.com Guest
Posted: Thu Nov 29, 2007 10:55 am Post subject: XL baggage compartment fan |
Terry, if you cannot find a large enough sunscreen for
an automobile, the screens are made from a insulating
material known as Astrofoil.
Astrofoil should be available in rolls from a home and
building store such as Home Depot or Lowes. It comes
in several different widths as legnths. It's been a
while since I bought some but the price was not too
bad if I remember correctly.
Hope this helps
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
sections for easy
weighs 13 oz.
Terry
Be a better pen pal.
Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/
Gig Giacona
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Thu Nov 29, 2007 3:01 pm Post subject: XL baggage compartment fan |
Chris--
I installed a 2 inch one in the forward panel above the instruments and a 6 inch one at the rear of the baggage compartment. They have come in handy for defogging and do assist with some cooling. The only real way to cool the cockpit when stopped or taxing, however, is to pop the canopy up a bit
bryanmmartin
Posted: Thu Nov 29, 2007 3:35 pm Post subject: XL baggage compartment fan |
I prop open the canopy while taxiing. I made a prop that keeps the canopy partly open and prevents it from blowing open in the wind. This keeps the cockpit reasonably cool during taxi. I have a canopy cover from Bruce's Custom Covers that does a good job of keeping the cockpit cool when parked. I recently added a Koger sunshade and a couple of Vista Vents to help keep the cabin comfortable in the air on very hot days.
On Nov 29, 2007, at 8:47 AM, chris Sinfield wrote:
Quote: | --> Zenith-List message posted by: "chris Sinfield" <chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)>
Hi
Chris
Bryan Martin
N61BM, CH 601 XL,
RAMSubaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
shilcom
Posted: Fri Nov 30, 2007 2:32 am Post subject: XL baggage compartment fan |
Are those computer fans 12VDC. Wouldn't think they would run off the computer power supply that they are cooling. bob U.
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Fri Nov 30, 2007 3:44 am Post subject: Re: XL baggage compartment fan |
Yes they are 12vdc, this is available on a desk top PC power supply.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
Posted: Fri Nov 30, 2007 7:20 am Post subject: XL baggage compartment fan |
Yep, mine both run on 12VDC,
Dred
---- Bob Unternaehrer <shilocom(at)mcmsys.com> wrote:
[quote] Are those computer fans 12VDC. Wouldn't think they would run off the computer power supply that they are cooling. bob U.
bryanmmartin
Posted: Fri Nov 30, 2007 2:40 pm Post subject: XL baggage compartment fan |
Nearly every circuit in a personal computer runs on 12VDC or less. Most of the circuits run on 5VDC or less.
On Nov 30, 2007, at 5:28 AM, Bob Unternaehrer wrote:
Quote: | Are those computer fans 12VDC. Wouldn't think they would run off the computer power supply that they are cooling. bob U.
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
archerm
Posted: Sat Dec 01, 2007 5:50 am Post subject: XL baggage compartment fan |
I used a 12 volt computer fan. I got it off of EBay. It works fine.
Doesn't pull a lot of air. But it does get some movement. Which should
help
http://www.zodiacxl.com/Top%20Skin%20Assy.htm
Good Luck
Matt
www.zodiacxl.com
_________________ Matt
www.zodiacxl.com |
