DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Tue Dec 04, 2007 11:55 am Post subject: Throttle to carb connection |
I'm concerned that the method I use to secure the throttle cable to the carburetor on my Jab 2200 is not sufficient or safe. Need some opinions before I redesign the connection. The throttle cable is connected to an ACS wire grip, PN 05-16000 which is then connected to the carburetor lever. The systems worked well but I'm concerned the wire grip may let loose at bad time. Any advice will be appreciated
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
Lynn Matteson
Posted: Tue Dec 04, 2007 2:17 pm Post subject: Throttle to carb connection |
Hi Dan-
On my installation I used an internally threaded aluminum rod of
about 3/16" diameter and about 1/2" long, as the connection to the
carb arm/lever. I did NOT use the questionable stuff that came with
the engine. I used an Aircraft Spruce vernier throttle control which
uses a solid wire as the actual link to the carb lever. What the
3/16" threaded rod does is goes through the carb lever, and allows
the throttle control wire to pass through it...crossways. The
internal threads are 8-32, as I recall, threaded all the way through
the 1/2" long aluminum rod. I then used 8-32 set screws from both
sides of the rod, and this grips the throttle control wire. I don't
have any pictures of this at this time...sorry.
I hope I've explained it well enough. It's a pretty simple, but
effective way of gripping the control wire, and pivots within the
carb lever as it should. If adjustments are necessary, loosening one
or both of the set screws will allow for that.
Lynn Matteson
flying w/440+ hrs
appreciated
Dan Mc Intyre
Kitfox Model IV, Jab 2200
http://forums.matronics.com/viewtopic.php?p=150411#150411
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
valleyairport(at)cotterwe Guest
Posted: Tue Dec 04, 2007 3:05 pm Post subject: Throttle to carb connection |
Dan,
I have the wire grip on my Lycoming powered Kitfox. Seventy hours so
far and no signs of it letting go. I am going to use the same system on my
Jab 3300 engine project. To me, the spring that pulls the throttle to full
open is a hazard and will be removed. With no spring pulling there will be
little force applied to the grip/wire junction.
Jay C.
Lynn Matteson
Posted: Tue Dec 04, 2007 7:35 pm Post subject: Throttle to carb connection |
I think I'd rather have the throttle go to WOT and control the plane
by using the mag switch, than to have to try to find a landing spot
with no power. What about an over-water broken throttle control?
Lynn Matteson
flying w/440+ hrs
On Dec 4, 2007, at 6:05 PM, Jay & Beverly wrote:
<valleyairport(at)cotterweb.com>
Dan,
hours so
system on my
to full
will be
Jay C.
N369LM |
DanM
Posted: Wed Dec 05, 2007 6:38 am Post subject: Re: Throttle to carb connection |
Thanks for the information guys. Since Jay has been successful with the wire grip, I may not change mine. Lynn, how is the internally threaded rod attached to the carb lever. I can't picture it from your comments. More on my set up, I have a ACS vernier throttle which is connected to ACS wire grip in question, the wire grip is then connected to a rod end which is connected to the carb lever. I might add, the carb lever is special design and built by Dave Jalanti. His design add more throw to carb lever which gives more travel to the vernier throttle thus finer adjustments. Heres some photos of my set up.
Description: |
Filesize: |
344.67 KB |
Viewed: |
649 Time(s) |
Description: |
Filesize: |
381.72 KB |
Viewed: |
604 Time(s) |
Kitfox IV
Sensenich 62x46
N443DM |
msm_9949(at)yahoo.com Guest
Posted: Wed Dec 05, 2007 7:49 am Post subject: Throttle to carb connection |
Kinda like flying a Sopwith Camel, eh Lynn?
Lynn Matteson <lynnmatt(at)jps.net> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson
Lynn Matteson
flying w/440+ hrs
[quote] --> Kitfox-List message posted by: "Jay & Beverly"
Dan,
hours so
system on my
to full
will be
Jay C.
Lynn Matteson
Posted: Wed Dec 05, 2007 8:37 am Post subject: Throttle to carb connection |
Dan-
I also have the Dave Jalanti-designed lever/arm. I'm going to the
hangar in about an hour and I'll shoot some pictures of mine...I
already have the cowl off. As I recall building it, the internally-
threaded rod has a head (forgot to mention that last night) and it
slides through the Jalanti arm, with the throttle wire going through
the cross hole securing the rod from going back through the arm. Then
the set screws secure the wire to the rod.
I'll get some pics.
Lynn
Dan Mc Intyre
http://forums.matronics.com/viewtopic.php?p=150562#150562
http://forums.matronics.com//files/p1010004_182.jpg
http://forums.matronics.com//files/p1010005_846.jpg
N369LM |
Lynn Matteson
Posted: Wed Dec 05, 2007 8:43 am Post subject: Throttle to carb connection |
Hey Marco, I'm not THAT old! : )
Lynn
On Dec 5, 2007, at 10:48 AM, Marco Menezes wrote:
[quote] Kinda like flying a Sopwith Camel, eh Lynn?
Lynn Matteson
flying w/440+ hrs
> Dan,
> hours so
> system on my
> to full
> will be
> Jay C.
N369LM |
kcflys
Joined: 28 Aug 2007 Posts: 33 Location: Rancho Cordova, CA
Posted: Wed Dec 05, 2007 9:49 am Post subject: Re: Throttle to carb connection |
Dan & Lynn,
Not for sure but Lynn's description sounds a lot like the old VW throttle and heater cable connections.
Do Not Archive.
_________________ Keith C.
kitfox wannabe
C-150
Rancho Cordova CA |
Lynn Matteson
Posted: Wed Dec 05, 2007 12:15 pm Post subject: Throttle to carb connection |
Your installation looks very good, Dan. It sure looks more rugged
than mine. However, I've got over 400 hours on mine and it hasn't
given up yet. I tried to find that "grip" device in the Spruce
catalog, but no such luck.
Lynn Matteson
flying w/440+ hrs
Dan Mc Intyre
N369LM |
jose_m_toro(at)yahoo.com Guest
Posted: Wed Dec 05, 2007 1:12 pm Post subject: Throttle to carb connection |
Lynn:
I just did the search. It is called wire grip and is located in page 149 of the ACS catalog.
José
Lynn Matteson
Posted: Wed Dec 05, 2007 5:51 pm Post subject: Throttle to carb connection |
Thanks, Jose...I went there and nothing, but wandering a little
further I found it on page 159 of both of my Spruce (ACS?) catalogs...
2006-2007 and 2007-2008. Do you have an older catalog, or is ACS not
Aircraft Spruce? I'm not being picky, but I've never been able to
equate ACS with Aircraft Spruce and Specialty Co....the letters just
don't seem to come out right.
That item seems like a nice way to terminate a control wire.
Lynn
On Dec 5, 2007, at 4:10 PM, Jose M. Toro wrote:
<jose_m_toro(at)yahoo.com>
Lynn:
José
N369LM |
Posted: Wed Dec 05, 2007 7:01 pm Post subject: Throttle to carb connection |
Lynn:
AirCraft Spruce. They sell many parts with the ACS brand. Two of those are the ignition switch and the gascolator.
I found the wire grip searching on their website. The pdf I got shows page 149.
I also have the adapter from Dave Jalanti, and have been thinking about doing exactly what you did. However, the wire grip looks elegant...
Jose
Michel
Posted: Thu Dec 06, 2007 12:09 am Post subject: throttle to carb connection |
Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
Here's my 3rd and last attempt at posting pictures
Lynn, your photos came through but with extra files. Those extras are the resource part, including thumbnails, from your Macintosh formatting. To avoid that, select your file, press Apple+I, click the thumbnail in the Info window of the file then click Delete.
Your file icon will now be without thumbnail but the file will be smaller and more 'PC-friendly.'
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Fox5flyer Guest
Posted: Thu Dec 06, 2007 4:40 am Post subject: Throttle to carb connection |
My NSI Subaru uses two of these wire grips, one for the carb heat, and one
for the mixture control. They seem to work very well, but you need to keep
an eye on them. One thing they do when gripping the wire is they put a
bunch of little cuts into it from the gripping jaws. One day when I pulled
the carb heat knob it came all the way out, not stopping at the usual 3
inches. When I later inspected the wire I found that it broke off right at
the point where the gripping cuts were. I use good quality Boden Cables
too. Not a real big deal for carb heat.
However, the other wire grip on the mixture control is the one that bothers
me. If it broke, my mixture would go to full lean which will allow the
engine to run at cruise rpm and lower, but not at climb power, the worst
place. If it broke at this point, it could be a real problem. I solved
that by adding a spring to the mixture arm that, if the cable were to break,
the arm would go to full rich.
My suggestion is that if you use them, don't put one on the throttle cable.
Not a good place for something that needs to be nearly 100 percent reliable.
There is a better connector for the throttle control and I'll try to find it
and post to the list.
Deke Morisse
S5/Subaru
NE Michigan
Posted: Thu Dec 06, 2007 5:16 am Post subject: Throttle to carb connection |
Deke:
This is a very valuable advice.
Thanks!
José Toro
My suggestion is that if you use them (wire grip), don't put one on the throttle cable.
Fox5flyer Guest
Fox5flyer Guest
Posted: Thu Dec 06, 2007 6:15 am Post subject: Throttle to carb connection |
Well, we could call it ASS, but I don't think Aircraft Spruce and Specialty
would be real quick to change their acronym.
Deke
Thanks, Jose...I went there and nothing, but wandering a little further I
found it on page 159 of both of my Spruce (ACS?) catalogs... 2006-2007 and
2007-2008. Do you have an older catalog, or is ACS not Aircraft Spruce?
I'm not being picky, but I've never been able to equate ACS with Aircraft
Spruce and Specialty Co....the letters just don't seem to come out right.
Lynn
> Lynn:
> José
Lynn Matteson
Posted: Thu Dec 06, 2007 7:10 am Post subject: Throttle to carb connection |
Actually, they call themselves Aircraft Spruce & Specialty COMPANY,
so ASSC or ASS Company might work. Come to think of it, ASS Company
is sometimes very descriptive of how they work, especially in the
catalog department.
Ok, I'll get on the bandwagon with everybody else and accept ACS, but
it ruffles my anal feathers to break the word "aircraft" into two
words....but that's just me.
Lynn
On Dec 6, 2007, at 9:11 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
Specialty would be real quick to change their acronym.
Deke
> catalogs... 2006-2007 and 2007-2008. Do you have an older catalog,
> or is ACS not Aircraft Spruce? I'm not being picky, but I've
> never been able to equate ACS with Aircraft Spruce and Specialty
> Lynn
>> Lynn:
>> José
N369LM |
MichaelGibbs(at)cox.net Guest
Posted: Thu Dec 06, 2007 7:55 am Post subject: Throttle to carb connection |
Lynn sez:
Quote: | ...it ruffles my anal feathers to break the word "aircraft" into two words...
Tell your feathers to relax, Lynn. According to Kiktionary.com
<http://en.wiktionary.org/wiki/aircraft>, the term comes from a
"craft" that operates in the "air". "Air + craft" is the listed
etymology.
Mike G.
N728KF
Phoenix, AZ
