Jugle
Joined: 04 Aug 2007 Posts: 47 Location: Victoria, Australia
Posted: Mon Dec 03, 2007 8:02 pm Post subject: Avex Rivets |
Hello all,
I've been looking at the price of rivets on the Zenith site and comparing with those from Aircraft Spruce. The Aircraft Spruce ones are substantially cheaper but are they suitable? They refer to them as Avex Non-structural Blind Rivets, countersunk Part Nos. 1604-0412, 1604-0514 and 1604-0615. Are these the correct type?
I got a quote from Zenith for a hardware box which goes for $425.00 but apparently it doesn't include rivets.
What have you other scratchbuilders done?
Thanks in advance,
Glenn
_________________ Glenn Andressen
601XL- Rudder, Stabiliser parts completed, Wing ribs, nose ribs done, 70% Fuselage parts made. |
dougsnash(at)yahoo.com Guest
Posted: Tue Dec 04, 2007 3:57 am Post subject: Avex Rivets |
Personally, I'm using the Aircraft Spruce rivets.
Haven't had any issues. I belive the rivets that
Zenith sells are from a certain Avex plant and have a
more consistant breakaway of the stem when pulled.
Occasionally, the Spruce rivets do have a slight
protrusion of the broken stem. It happens but not
very often.
Best of luck with your build
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
--- Jugle <glenn(at)eastcoastit.net> wrote:
Hello all,
the correct type?
rivets.
Thanks in advance,
Glenn
Glenn Andressen
601XL- just started.
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Tue Dec 04, 2007 10:48 am Post subject: Re: Avex Rivets |
dougsnash(at)yahoo.com wrote: | Personally, I'm using the Aircraft Spruce rivets.
I belive the rivets that Zenith sells are from a certain Avex plant and have amore consistant breakaway of the stem when pulled.
Occasionally, the Spruce rivets do have a slight protrusion of the broken stem. It happens but not very often.
I also used ACS rivets. I'd also purchased some A6's from ACS and from one other vendor (at Oshkosh) - the ones from ACS had a more consistent appearance and appeared to be of better quality which compares well with the ones supplied from Zenith. I've only used rivets from Zenith and from ACS. I threw away the ones I got from the other vendor.
As far as the stems pulling off cleanly, I think that's more "luck of the draw". About 1 out of 4 of my Zenith supplied A5's have a sharp tip sticking up.
Run your hand along your wing rivet lines and you'll see what I mean. I'm not too worried about it, but if I were polishing my wings I would be as it would tear up polish pads in short order.
Patrick
XL/Corvair
Gig Giacona
Posted: Tue Dec 04, 2007 11:33 am Post subject: Re: Avex Rivets |
That's strange. I've riveted the tail, both wings and most of the fuselage with nothing but the rivets from Zenith and I have never had one that left a tip of any kinds sticking up.
[/quote]
Patrick
XL/Corvair[/quote]
601XL Under Construction
carlossa52(at)gmail.com Guest
Posted: Tue Dec 04, 2007 12:48 pm Post subject: Avex Rivets |
Same with me - and I got mine from Textron, in TO, before production was moved to China.
(This did happen with the cherry q rivets I used on the fuel tanks).
My next batch is coming from Zenith.
Carlos
CH601 HD, plans
On 04/12/2007, Gig Giacona <wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)> wrote:[quote] --> Zenith-List message posted by: "Gig Giacona" <wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)>
n801bh(at)netzero.com Guest
Posted: Tue Dec 04, 2007 1:15 pm Post subject: Avex Rivets |
I am going to chime in here. On my 801 I built in 2001 every one of the ZAC supplied Rivets always pulled correctly and out of 14,000+, none ended up with a shank sticking out. The only difficult ones were the Stainless ones used on the firewall. They just broke the air riveter. :<(.
Ben Haas
N801BH
www.haaspowerair.com
-- "PatrickW" <pwhoyt(at)yahoo.com> wrote:
--> Zenith-List message posted by: "PatrickW" <pwhoyt(at)yahoo.com>
Patrick
XL/Corvair
http://forums.matronics.com/viewtopic.php?p=150395#150395
========================bsp; -- Please Support Your Lists This Month -- [quote][b]
john.marzulli(at)gmail.co Guest
Posted: Tue Dec 04, 2007 1:30 pm Post subject: Avex Rivets |
I've have some rivets ( Zenith provided ) on my fuselage with the shank not having cleanly torn away and have been trying to figure out what to do about them.
Is it safe to leave them, is it OK to "clean them up" with a file, or would it be best to drill them out and re-rivet those holes?
On Dec 4, 2007 1:11 PM, n801bh(at)netzero.com (n801bh(at)netzero.com) <n801bh(at)netzero.com (n801bh(at)netzero.com)> wrote:
Quote: | I am going to chime in here. On my 801 I built in 2001 every one of the ZAC supplied Rivets always pulled correctly and out of 14,000+, none ended up with a shank sticking out. The only difficult ones were the Stainless ones used on the firewall. They just broke the air riveter. :<(.
Ben Haas
N801BH
-- "PatrickW" <pwhoyt(at)yahoo.com (pwhoyt(at)yahoo.com)> wrote:
--> Zenith-List message posted by: "PatrickW" <pwhoyt(at)yahoo.com (pwhoyt(at)yahoo.com)>
Patrick
XL/Corvair
John Marzulli
http://701Builder.blogspot.com/
"Flying a plane is no different than riding a bicycle... it's just a lot harder to put baseball cards in the spokes.
-Airplane The Movie [quote][b]
Jugle
Posted: Tue Dec 04, 2007 1:53 pm Post subject: Re: Avex Rivets |
Thanks for your replies. One thing I find curious is that Aircraft Spruce refer to them as "Avex Non-Structural Blind Rivets". I've never heard of them referred to as non-structural anywhere else.
Anyone know why this is?
Glenn
bryanmmartin
Posted: Tue Dec 04, 2007 4:12 pm Post subject: Avex Rivets |
The answer is -- yes.
You can just leave them as is, unless the appearance really bothers
you. If so, you can either clean up the stem with a file, as long as
you don't damage the aluminum part of the rivet. Even if you do damage
the rivet, there are more rivets in the plane than are really needed
for structural strength. If all else fails, drive out the stem with a
small pin punch and then it will be very easy to drill out and replace.
On Dec 4, 2007, at 4:28 PM, John Marzulli wrote:
Quote: | I've have some rivets ( Zenith provided ) on my fuselage with the
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
cj.tremblay(at)videotron. Guest
Posted: Tue Dec 04, 2007 5:38 pm Post subject: Avex Rivets |
I Glenn
Avex Rivets that you specifies on you email are the good ones. Avex rivets
are Avex rivets. Chris H. made special disclosure about testing the rivets,
you can do those test if you want. Big confusion exist about Avex rivets
base on Chris H declaration about those rivets, somebody said only those
produce in UK are ok, others could be produced in China? But who now where
Avex produced their stuff today ?
Buy the rivets sold by Spruce Aircraft and don't let anybody confuse you on
that question. If they are produce by Avex in sold by Aircraft Spruce, I
believe they are ok. I used thousand of them, never find one defective.
Some time to much opinion is too much and it's confuse the builder judgment.
Christian Tremblay
A guy who build a CH640 aircraft from plan
http://www.zodiac640.com/
-----Message d'origine-----
De : owner-zenith-list-server(at)matronics.com
[mailto:owner-zenith-list-server(at)matronics.com] De la part de Jugle
Envoyé : Monday, December 03, 2007 11:03 PM
À : zenith-list(at)matronics.com
Objet : Avex Rivets
Hello all,
Thanks in advance,
Glenn
Glenn Andressen
http://forums.matronics.com/viewtopic.php?p=150292#150292
Jugle
Posted: Wed Dec 05, 2007 9:30 pm Post subject: Re: Avex Rivets |
Thanks Christian, you and others here have helped to clarify.
Glenn
cj.tremblay(at)videotron. wrote: |
TxDave
Posted: Wed Dec 05, 2007 11:17 pm Post subject: Re: Avex Rivets |
Zenith no longer gets their Avex rivets from the UK. There is only one source and that's in China. The UK plant is no longer producing these rivets. The ones Zenith purchases are from the same source as Aircraft Spruce. There is NO DIFFERENCE except that Zenith runs random tests. Don't believe me...call ZAC and ask them. I did.
Dave Clay
ashontz
Posted: Thu Dec 06, 2007 4:04 am Post subject: Re: Avex Rivets |
Could just be the rivet puller too.
Gig Giacona wrote: | That's strange. I've riveted the tail, both wings and most of the fuselage with nothing but the rivets from Zenith and I have never had one that left a tip of any kinds sticking up.
Patrick
XL/Corvair[/quote][/quote]
Posted: Thu Dec 06, 2007 6:18 pm Post subject: Avex Rivets |
Thanks Dave, that confirms what I heard about that topic. It clarifies this
remaining questions arising season after season.
See you
How was your new project ?
Christian Tremblay
[mailto:owner-zenith-list-server(at)matronics.com] De la part de TxDave
Envoyé : Thursday, December 06, 2007 2:18 AM
Objet : Re: Avex Rivets
Dave Clay
http://forums.matronics.com/viewtopic.php?p=150704#150704
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Thu Dec 06, 2007 6:46 pm Post subject: Re: Avex Rivets |
I've never had a Zenith supplied rivet leave any of the shank protruding. I got my rivets in June 06 so they may be some that were made in the UK.
I've seen a number of problems with Chinese built products - poison pet food, bogus drugs and personal products, aluminum that doesn't meet spec, inferior auto parts, lead paint on toys...... pardon me if I'm not a fan of Chinese exports.
The fact that avex rivets are now made in China does not reassure me.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
rlalonde
Posted: Thu Dec 06, 2007 9:39 pm Post subject: Avex Rivets |
In defence of Chinese made products, (which I agree are inferior on the most part) it had been discovered that many of the products (especially the lead paint on toys) were produced by specifications and engineering requested by North American companies!! They produced what was requested, at a price well below of what it could be made in the US or Canada.
You get what you pay for. If there is a market for "cheap" you get "cheap". Avex rivets......if you test them like Zenith Aircraft suggests, it is a safe bet they are ok. Pay your money, and take your chances....who says the UK rivets were any better?? UK hasnt made them for a few years and I havent seen any reports indicating either positive or negatively.
Just something to think about.
Ron
> Subject: Re: Avex Rivets
Quote: | From: juhl(at)avci.net
Date: Thu, 6 Dec 2007 18:46:07 -0800
--> Zenith-List message posted by: "Tim Juhl" <juhl(at)avci.net>
______________
CFII
Champ L16A flying
Working on wings
http://forums.matronics.com/viewtopic.php?p=150924#150924
&g========================
HO HO HO, if you've been naughty this year, email Santa! Visit asksanta.ca to learn more! [quote][b]
ashontz
Posted: Fri Dec 07, 2007 3:29 am Post subject: Re: Avex Rivets |
Hurray for globalization!!! NOT!!!
I knew NAFTA was a bunch of crap back in 1992, and I was only 23 at the time. I thought to myself then, ok, we're in a recession, I'm finding it difficult to find a job out of college with a usable degree in computer science and Clinton retard is making promises to give even more jobs to foreigners. Bush Sr. and Jr. also helped that along, typical Republicrats. NAFTA and globalization is nothing more than help for corporate socialists in this country (facists) to make it easier for the top .1% to make even more money under the US flag while first off not even being an actual US company and secondly taking all of those jobs away from Americans and making them work for less at crappy Wal-Mart greeter jobs and then encouraging them to find 'wealth' through borrowing against asset inflation (housing bubble home equity loans). THis country is royally screwed. Call me a nut, but we are at the cusp of a second Greater Depression and this credit crunch and housing slump are just the tip of the iceberg. These globalization/trade deficit created debts are now coming due with deflation in leveraged assets (housing) and inflation in everything else you need, particularly commodities. The only candidate that's addressing any of this is Ron Paul, running as a Republican (because he;s always been a REAL conservative not a NeoCon) but a Libertarian at heart. Think first before you vote this time around.
I know there's older guys on here so this one may bring it a little closer to home for you. If you think you're safe for retirement and invested well, think again. Look at your investment mutual funds. Most of them are tainted with a lot of what's called commercial paper and mortgage backed securities. Wallstreet has been packaging these crappy subprime loans along with other supposedly safe investments and calling it all AAA rated which is what pension funds are only allowed to buy. The pension funds then are expecting a safe return as well as the share value of that fund to always be equal to $1. Well, now that housing is going in the crapper, those fund shares have an indeterminate value (meaning their crap). Google Florida Fund. Their whole pension and munipal funds system is all screwed up right now as will many others be.
Rant off.
[quote="rlalonde"]In defence of Chinese made products, (which I agree are inferior on the most part) it had been discovered that many of the products (especially the lead paint on toys) were produced by specifications and engineering requested by North American companies!! They produced what was requested, at a price well below of what it could be made in the US or Canada.
Ron
--> Zenith-List message posted by: "Tim Juhl" <juhl>
______________
CFII
Champ L16A flying
Working on wings
planecrazydld(at)yahoo.co Guest
Posted: Fri Dec 14, 2007 8:47 pm Post subject: Avex Rivets |
I prefer to level the residual pintail by "dusting" it down flush with the rivet head in a series of light touches with a Dotco or similar very high speed grinder (sanding disc grinder). The problem with filing it down is that the pressure and vibration of filing are in cahoots to reduce the pintail retention system of the fastener (not the greatest to start with)
John Marzulli <john.marzulli(at)gmail.com> wrote:[quote] I've have some rivets ( Zenith provided ) on my fuselage with the shank not having cleanly torn away and have been trying to figure out what to do about them.
[quote] I am going to chime in here. On my 801 I built in 2001 every one of the ZAC supplied Rivets always pulled correctly and out of 14,000+, none ended up with a shank sticking out. The only difficult ones were the Stainless ones used on the firewall. They just broke the air riveter. :<(.
Ben Haas
N801BH
Run your hand along your wing rivet lines and you'll see what I mean. I'm not too worried about it, but if I were polishing my wings I would be [quote][b]
PatrickW
Posted: Sat Dec 15, 2007 9:33 am Post subject: Re: Avex Rivets |
ashontz wrote: | Could just be the rivet puller too. |
I'm now using a better rivet puller, but still get some A5's that leave a sharp tip poking up. I also have another box of fresh A5's from Zenith that I'll be using next, so it'll be interesting to see how those are.
Not a big problem - I'll just dremel down the sharp tips of the worse ones and move on.
Patrick
XL/Corvair
