BLAST TUBES FOR THE MAGS
dlm46007(at)cox.net
PostPosted: Thu Dec 06, 2007 9:35 am    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
I may have ask this question before but are any using the blast tubes in the baffling to cool the mags. never had these on a certified or experimental; never needed.
Tim Olson
PostPosted: Thu Dec 06, 2007 10:05 am    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
I put one in....don't know if it's useful or not.
jesse(at)saintaviation.co
PostPosted: Thu Dec 06, 2007 11:12 am    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
same here
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Deems Davis
PostPosted: Thu Dec 06, 2007 11:22 am    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
I spoke to Allen Barrett about the need for blast tubes. what I learned
was that Mags are not fond of heat. In a Pitts, it is nearly mandatory
to put in blast tubes as there is a lot of heat behind the baffles, and
the mags don't last without the tubes. I don't know how much heat the
-10 holds in the aft engine compartment, but living in the desert, I'm
sensitive to anything that's affected by the heat, and so I put one in
for each mag. I used the Van's corrugated plastic tube, and wrapped each
with a coil of #10 coper wire to bend/aim them at the mags. However,
based on what I learned in the paragraph below, I believe this is going
to be too much and I may fashion some restrictors that provide a smaller
diameter opening. I saw Allen Judy's highly modified RV6 (at) OSH this year
and he's got blast tubes of a very small diameter Scat Tube ( 3/8"?)
On a related note, I recently spoke with a -10 builder in OK who just
completed his plane and is now flying. He reported the HTS (Hot Tunnel
Syndrome) phenomena. He has John Forsling exhaust and the Forsling
Ceramic coated heat muffs. One mounted on each side of the engine on the
exhaust stacks. John warned us that the heat muffs might not produce
enough heat as the exhaust is ceramic coated both inside and outside.
That turned out NOT to be the case. The air to the muffs is fed by a
single 2" opening at the rear baffle behind cyl #5. The solution to the
heat problem for this builder was to put a restrictor plate in front of
the 2" air inlet. He experimented with how big the hole in the
restrictor plate should be and FOUND THAT 1/4 " ONE QUARTER OF AN INCH
was all that was needed to supply all the air He needed for front and
aft cabin on a 40 degree OAT day!!!!! It solved his HTS problem and
still provided all of the heat he needs.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
n223rv(at)wolflakeairport
PostPosted: Thu Dec 06, 2007 11:44 am    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
I have one too
PostPosted: Thu Dec 06, 2007 12:05 pm    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
Very good real life example of a fix for HTS. Anybody else with HTS
want to try covering the holes and seeing what happens? One thing I
know from experience is that I have never seen the heater valves
opened very far. You will cook yourself if you do.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
learned was that Mags are not fond of heat. In a Pitts, it is
nearly mandatory to put in blast tubes as there is a lot of heat
behind the baffles, and the mags don't last without the tubes. I
don't know how much heat the -10 holds in the aft engine
compartment, but living in the desert, I'm sensitive to anything
that's affected by the heat, and so I put one in for each mag. I
used the Van's corrugated plastic tube, and wrapped each with a coil
of #10 coper wire to bend/aim them at the mags. However, based on
what I learned in the paragraph below, I believe this is going to be
year and he's got blast tubes of a very small diameter Scat Tube
( 3/8"?)
just completed his plane and is now flying. He reported the HTS (Hot
Tunnel Syndrome) phenomena. He has John Forsling exhaust and the
Forsling Ceramic coated heat muffs. One mounted on each side of the
engine on the exhaust stacks. John warned us that the heat muffs
might not produce enough heat as the exhaust is ceramic coated both
inside and outside. That turned out NOT to be the case. The air to
the muffs is fed by a single 2" opening at the rear baffle behind
cyl #5. The solution to the heat problem for this builder was to
put a restrictor plate in front of the 2" air inlet. He experimented
with how big the hole in the restrictor plate should be and FOUND
THAT 1/4 " ONE QUARTER OF AN INCH was all that was needed to supply
all the air He needed for front and aft cabin on a 40 degree OAT
day!!!!! It solved his HTS problem and still provided all of the
heat he needs.
Deems Davis # 406
speckter(at)comcast.net
PostPosted: Thu Dec 06, 2007 1:08 pm    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
I wonder what size hole you need for a -10 Minnesota day?
Gary
Back in MN for the holidays
[quote] --> RV10-List message posted by: Deems Davis
the 2" air inlet . He e > _ ://for [quote][b]
scottmschmidt(at)yahoo.co
PostPosted: Thu Dec 06, 2007 3:09 pm    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
I have one mag and one lightspeed and no blast tube.
Never had a problem yet. Maybe I'll be adding one at the next oil change.
Scott Schmidt
msausen
PostPosted: Fri Dec 07, 2007 7:16 pm    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
Deems,
Do you know if he had John add the turndown on the pipe end or was he running the straight pipe?
Michael
Deems Davis
PostPosted: Fri Dec 07, 2007 7:48 pm    Post subject: BLAST TUBES FOR THE MAGS Reply with quote
Mike, this builder did NOT have the turn downs on the exhaust tips. i
asked him if he was certain as to the source of the heat, and he felt
certain it was the heat muffs.
Deems
RV Builder (Michael Sausen) wrote:
Deems,
