Gary
Joined: 20 Oct 2007 Posts: 13 Location: Toronto, Ontario, Canada
Posted: Fri Dec 14, 2007 4:17 pm Post subject: Primer installation 912UL |
Hello 912 users
Does anyone know where to install the fuel primer lines on the 912UL? I've read all the past posts on proper starting procedures and how a primer isn't necessary but I'd like to put a squirt button in my KF anyway.
_________________ Gary Del Bel Belluz
Toronto, IV / 912UL
Just getting started |
wingnut
Posted: Fri Dec 14, 2007 5:24 pm Post subject: Re: Primer installation 912UL |
Please post results when you get this sorted. I'm interested in doing the same for mines.
Quote: | Does anyone know where to install the fuel primer lines on the 912UL? I've read all the past posts on proper starting procedures and how a primer isn't necessary but I'd like to put a squirt button in my KF anyway. |
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
kitfoxpilot(at)msn.com Guest
Posted: Fri Dec 14, 2007 6:02 pm Post subject: Primer installation 912UL |
If you have a gascolator, you can run the draw from that point to the primer, then run a line from the primer to a T fitting then to each carb! thats how I have mine set up.
Ray
Quote: | Subject: Re: Primer installation 912UL
Date: Fri, 14 Dec 2007 17:24:18 -0800
--> Kitfox-List message posted by: "wingnut" <wingnut(at)spamarrest.com>
Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A)
http://forums.matronics.com/viewtopic.php?p=152249#152249
Share life as it happens with the new Windows Live. Share now! [quote][b]
john(at)leptron.com Guest
Posted: Fri Dec 14, 2007 6:15 pm Post subject: Primer installation 912UL |
Luis,
The primer line as far as I am concerned is necessary. Every engine that we
have installed this on has started every time on 2 blades or less. If you
think about it that is a great improvement.
Under the carb if you look close there is a barbed fitting with a screw in
the middle.
You will need to split t0 both carbs and this creates a problem. At low
speed or warm up time the carbs are not flowing the same. So what happens is
one carb will suck all the fuel from the crossover line. If this line is
more than the normal 1/16 primer line it can cause the engine to stumble for
quite a time. Of course this would negate the primer.
I tried several types and sizes of primer line before realizing that the
aircraft world had already been through this.
I use a short stroke aircraft primer and this is enough, but any aircraft
primer will do.
After you split (as close to the engine as you can) the line and run to the
carbs, I put a 20 thousandths safety wire in the end, hanging out and
sweated solder into the end. After the solder is set, I pulled the safety
wire out and now I have a 20 thousandths nozzle.
I push the line up and into the barbed fitting just flush with the carb
inside. A 1-inch piece of fuel line clamped to the barb and the line holds
it in place.
I can not push hard enough on the line size, it really does matter.
John Oakley
Speedster 4 long and short
912 ul cap
Gary
Posted: Fri Dec 14, 2007 8:01 pm Post subject: Re: Primer installation 912UL |
I'll take your advice and restrict the primer lines at the carb.
Thanks for the info.
Toronto, IV / 912UL
Gary
Posted: Mon Dec 17, 2007 7:18 pm Post subject: Re: Primer installation 912UL |
One final note from me. I managed to drill a .025 hole through the center of the 3.5mm screws that plugged the carb primer fittings. Then the head of the screw was filed down so the diameter matched the O.D. of the brass barbed fitting. The jets screw in nice and tight and the poly primer lines slip on normally.
Toronto, IV / 912UL
