ding(at)tbscc.com Guest
Posted: Mon Dec 10, 2007 2:03 pm Post subject: 601 steering slot cure / canopy progress |
The temp. limitation is a valid concern, and
probably the weak point in my particular installation, but I have no numbers
to go by. I can only say that, short of a fire, I don't expect it will get
warm enough in that location to be a problem. If it was something that had
potentially serious consequences upon failure, I would certainly be looking
more closely at that. I could replace the vinyl with thin aluminum tubing,
although it may not slide as freely, and might want to rattle. I may do that
if I have it apart again.
Probably should start a new thread, but I have my canopy
installation nearly complete. It was challenging, but that was in large part
due to self imposed causes. (1) I'm really too fussy about a perfect fit,
and that takes extra time, and (2) I raised the entire canopy about an inch
from standard position, because of my height. I flew the factory plane, and
while I had head clearance, It was minimal and more would be welcome.
Raising the canopy requires considerable extra work and time for just an
inch, but it turned out well. I'm glad I did it. If I learned anything that
might be of help to others, it would be this.--- I made temptates for the
front (and in my case, rear) trim strips using printing press aluminum
(.007"thick). I got it from our local newspaper. (I had to grovel
shamelessly to obtain a few sheets). It cuts with sissors and clecoes can
simply be pushed through it. I used several pieces per template and duct
taped them together as needed. A 2 inch piece of the rubber seal strip
served to adjust the clearance gap for a good seal without too much
pressure. The trim strips have a complex curve top and bottom when finished,
and I can't imagine getting them right without a system similar to this.
This thin sheet aluminum has the ideal characteristics for this job.
I also had to slightly dog-leg the lower canopy latch brackets to
get a flush outer skin fit while still maintaining the required bolt edge
distance where the bolts penetrate the upper front longerons. Wow, that
really sounds confusing. I wanted the rear side of the canopy frame to
be flush with the side of the plane below it. (does that help?)
Lynn
601XL / Corvair
Gig Giacona
Posted: Mon Dec 10, 2007 2:20 pm Post subject: Re: 601 steering slot cure |
OK, then this brings up a good question. Has anyone tested to see what the temp is around the firewall of a 601XL? If we have that number it is easy to test materiel we use there?
ding(at)tbscc.com wrote: | The temp. limitation is a valid concern, and
if I have it apart again.- |
601XL Under Construction
davgray(at)sbcglobal.net Guest
Posted: Mon Dec 10, 2007 3:40 pm Post subject: 601 steering slot cure / canopy progress |
Gig
My 601XL w/ WW cowl and WW corvair engine routinely tests about 100 degrees
above ambient behind the engine.
Gary Ray
Gig Giacona
Posted: Mon Dec 10, 2007 3:53 pm Post subject: Re: 601 steering slot cure / canopy progress |
If that is the case then there ought to be LOTS of plastics we can use and just triple the test temp for good measure.
I assume that is 100 F right?
davgray(at)sbcglobal.net wrote: | Gig
Gary Ray
Afterfxllc(at)aol.com Guest
Posted: Mon Dec 10, 2007 5:08 pm Post subject: 601 steering slot cure / canopy progress |
Zenith has a steering slot cure that goes on the AMD version but it isn't available to us. That kind of pisses me off...... It was on the online parts drawing http://www.zenithair.com/zodiac/xl/data/parts6xb13.pdf check out 6B7-4R, 6B7-4L, 6B7-5.
Jeff
In a message dated 12/10/2007 5:05:45 P.M. Eastern Standard Time, ding(at)tbscc.com writes:
[quote]--> Zenith-List message posted by: "dingfelder" <ding(at)tbscc.com>
Lynn
601XL / Corvair
Posted: Mon Dec 10, 2007 5:46 pm Post subject: 601 steering slot cure / canopy progress |
I saw those new parts on the diagram a while ago and asked the factory about them. The folks in MO said that they had just borrowed the diagram from AMD or Canada and didn’t make those parts. I believe they come out of Zenith Canada. The steering rods on the “super quick build kits” which come out of Canada (basically an unassembled AMD) also come with smooth steering rods with a short section of threads at one end.
It isn’t a complex design, I independently came up with the same idea before I saw the diagram. I did two things differently: instead of the jog which gives the slide room to move I used a separate spacer. And my plate had an “L” which allowed me to rivet them to the nose gear channel 6B8-2.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Afterfxllc(at)aol.com
Sent: Monday, December 10, 2007 6:05 PM
Subject: Re: Re: 601 steering slot cure / canopy progress
Jeff
Posted: Sat Dec 15, 2007 6:45 am Post subject: 601 steering slot cure / canopy progress |
please remember that this is the FIREWALL we are talking about here. Its purpose is to prevent flame from the passenger cabin. The steering rods traverse in and out of the hot/cold plane and if the rod is hot enough to ignite the plastic, it will burn on the inside as well.
The fumes generated are as big a concern as the flames...
Gig Giacona <wr.giacona(at)suddenlink.net> wrote:[quote] --> Zenith-List message posted by: "Gig Giacona"
[quote] Gig
Gig Giacona
Posted: Sat Dec 15, 2007 5:02 pm Post subject: Re: 601 steering slot cure / canopy progress |
I couldn't agree more. That's why I'm looking for a way to improve on the very leaky design that is in my set of 601XL plans.
planecrazydld(at)yahoo.co wrote: | please remember that this is the FIREWALL we are talking about here. Its purpose is to prevent flame from the passenger cabin. The steering rods traverse in and out of the hot/cold plane and if the rod is hot enough to ignite the plastic, it will burn on the inside as well.
Gig Giacona <wr> wrote:--> Zenith-List message posted by: "Gig Giacona"
Gig
sonar1@cox.net
Joined: 02 Oct 2007 Posts: 55 Location: Santa Barbara, Ca
Posted: Sat Dec 15, 2007 7:42 pm Post subject: Re: 601 steering slot cure / canopy progress |
Hi guys:
For the steering rods, I did something that I really like on my 701. It seems to work just fine.
I bought some nomex cloth - about as thick as denim, and non porous - and sewed up two triangular boots. I made a rectangular L-angle support for inside the cabin.
I have a portable CO detector, and have never had a rise above background reading.
Got the nomex and the kevlar thread on the internet somewhere.
This stuff will withstand really high temperatures.
Don't have a picture handy, but if interested, will find one.
Fred Sanford N9701 flew Sept '05, now building 9601 Santa Barbara, Ca.
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Sat Dec 15, 2007 9:05 pm Post subject: Re: 601 steering slot cure / canopy progress |
Where did you get the nomex and did you use nomex thread as well?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
NYTerminat(at)aol.com Guest
Posted: Sat Dec 15, 2007 9:15 pm Post subject: 601 steering slot cure / canopy progress |
Fred,
I would be interested in looking at that.
Bob Spudis N701ZX CH701/912s
In a message dated 12/15/2007 10:46:30 P.M. Eastern Standard Time, sonar1(at)cox.net writes:
See AOL's top rated recipes and easy ways to stay in shape for winter.
