jswanson(at)jamadots.com Guest
Posted: Fri Dec 14, 2007 9:20 am Post subject: Master switch |
I need help in wiring a cessna style split Master Switch Batt/Alt
into Z16 Rotax system. I'm using a single buss.
John S
CH701
nuckolls.bob(at)cox.net Guest
Posted: Sat Dec 15, 2007 11:22 am Post subject: Master switch |
At 11:43 AM 12/14/2007 -0500, you wrote:
| Quote: | I need help in wiring a cessna style split Master Switch Batt/Alt
Not sure how to answer this. The S700-2-10
switch shown in Z-16 emulates the functions
of a split-rocker switch. I.e. wiring diagrams
for both switches is identical.
You might check the panel of a Cessna but
the switch as-mounted uses the right side
rocker as the battery master and the left
side as the alternator. A check with your
ohmmeter would confirm that the battery side
can be ON without having the alternator
side ON too . . .
( -Thomas Paine 1776- )
Posted: Sat Dec 15, 2007 11:44 am Post subject: Master switch |
