BobsV35B(at)aol.com Guest
Posted: Sun Dec 16, 2007 1:31 pm Post subject: Battery Question? |
Good Afternoon,
I am sure this information is available somewhere in 'Lectric Bob's extensive library, but my searching skills are almost non existent.
I have the need for a twenty-eight volt battery set up for testing purposes. I would imagine something that would supply ten to fifteen ampere hours would be more than enough.
I do have several controllable bench power supplies to provide reasonable amperage and voltage, but a couple of twelve volt units in parallel would give me a nice stabilizing and cushioning device.
Could any one suggest a source of low cost batteries that might be suitable for use with a bench power supply?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
See AOL's top rated recipes and easy ways to stay in shape for winter.
Posted: Sun Dec 16, 2007 2:22 pm Post subject: Battery Question? |
Good Afternoon All,
Just as an addendum to my previous request, I did a google search and came up with something I thought may work.
Interstate Batteries lists a Power Patrol battery that seems about the right size. It is listed as being a 7.5 AH battery with a potential of handling 80 amps for up to five seconds and fifty amps continuously (For not long I would suppose!)
They also have a nice, though more expensive, unit that has an 18 AH rating and can handle 250 amps for five seconds, eighty amps continuously.
The big one would probably even handle a gear retraction or two!
I am leaning toward the purchase of a couple of the smaller ones. Any comments at all?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 12/16/2007 3:33:44 P.M. Central Standard Time, BobsV35B(at)aol.com writes:
| Quote: | Could any one suggest a source of low cost batteries that might be suitable for use with a bench power supply?
Posted: Sun Dec 16, 2007 2:38 pm Post subject: Battery Question? |
OOOPS!!
Should have said series as in:
"I do have several controllable bench power supplies to provide reasonable amperage and voltage, but a couple of twelve volt units in series would give me a nice stabilizing and cushioning device."
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
| Quote: | I do have several controllable bench power supplies to provide reasonable amperage and voltage, but a couple of twelve volt units in parallel would give me a nice stabilizing and cushioning device.
schaefer(at)rts-services. Guest
Posted: Sun Dec 16, 2007 3:32 pm Post subject: Battery Question? |
You can get 12V 7.5 Amp/Hour batteries in lots of places cheap.
They are used for:
Emergency Exit Signs and Uninterruptable Power Supply (UPS) for computers.
Check at your local big box hardware store in the electrical department or a local electrical or lighting supply house or check if there is a Batteries R US (Or something like that) near you.
Series for big volts, parallel for big amps J
r.t.s.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Sunday, December 16, 2007 4:36 PM
Subject: Re: Battery Question?
OOOPS!!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
| Quote: | | http://www.matronics.com/contribution | 012345678901234
nuckolls.bob(at)cox.net Guest
Posted: Sun Dec 16, 2007 7:58 pm Post subject: Battery Question? |
At 05:20 PM 12/16/2007 -0500, you wrote:
| Quote: | Good Afternoon All,
comments at all?
Can your power supplies be cranked up to 14.2 or thereabouts?
Also, you need to check and see how much (if any) current
flows back into the power supplies when they are powered-down
and still connected to batteries.
Using batteries to augment bench supplies is not an unreasonable
thing to consider. We used to do it in the two-way radio
business all the time. Most radios ran nicely in the receive
mode from a modest power supply but took 20+ Amps for
some of the big honkers. We would float a battery across
the power supply for temporary support of very intermittent
loads.
What kind of work are you wanting to accomplish with this
supply? If it's a relatively low priority, occasional kind
of activity, perhaps the batteries are your best bet . . .
but they are like houseplants . . . you gotta take care
of them.
How much current do you need at 28V . . . or would 24.0
do the job?
( -Thomas Paine 1776- )
Posted: Sun Dec 16, 2007 8:07 pm Post subject: Battery Question? |
comments at all?
Toss this idea in the hat. Theres a power supply on
ebay right now at:
http://tinyurl.com/2mzrkk
For a total cost of about $50 you can have a power
supply that will support 15A indefinitely and it's
probably only a little more expensive than a pair
of 7.5AH batteries. The best thing is that you
don't have to water, fertilize or pray over it
either!
Posted: Sun Dec 16, 2007 8:41 pm Post subject: Battery Question? |
Good Evening Bob,
"Can your power supplies be cranked up to 14.2 or thereabouts?
and still connected to batteries."
Darned if I know!
The primary one that I hope to use is a variable power supply that is supposed to be capable of supplying up to 40 volts and 25 amperes. It is a Hewlett-Packard 6438B which means absolutely nothing to me!
"What kind of work are you wanting to accomplish with this
of them."
I would like to use it to check out the aircraft systems.
Primarily electronics, but also the flaps, lights and, maybe, even the retractable landing gear. My intent is to hook the batteries to the airplane in lieu of the standard battery and power the whole thing with the power supply set at twenty-eight volts.
I hadn't considered leaving the power supply hooked up when not in use, but it would be interesting to know what would happen. I suppose I could hook an ammeter inline to see if there is any back flow.
I really have no idea what the intermittent loads will be, but steady state would rarely exceed fifteen amps. More often five to ten
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 12/16/2007 10:03:36 P.M. Central Standard Time, nuckolls.bob(at)cox.net writes:
loads.
do the job?
Posted: Sun Dec 16, 2007 8:45 pm Post subject: Battery Question? |
Good Evening Bob,
When using that address, I seem to be getting a 24 to 12 converter!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 12/16/2007 10:12:03 P.M. Central Standard Time, nuckolls.bob(at)cox.net writes:
Posted: Sun Dec 16, 2007 9:55 pm Post subject: Battery Question? |
At 11:32 PM 12/16/2007 -0500, you wrote:
| Quote: | Good Evening Bob,
Darned if I know!
Aha! These supplies have a crowbar ov protection
system in them that triggers if you leave them
connected across a battery and remove the incoming
AC power.
| Quote: | "What kind of work are you wanting to accomplish with this
of them."
Okay, you need to build up a "shop power
cart" consisting of two 12v batteries + the
HP power supply. I had just such a critter
for 1K1 while we owned it.
I got a metal "projector cart" on wheels at
Sam's Club. Office supply stores have them
too. Or you can built it out of wood. I'll
suggest that the 18 a.h. RG batteries that
you mentioned would be MINIMUM. These will have
tabs you can bolt up to. See:
http://www.aeroelectric.com/Mfgr_Data/Batteries/Panasonic/17AH.gif
You'll also want to put some form of ON/OFF
control on the cart. If you know someone that
runs a TC aircraft bone yard, you can probably
get your hands on a 6041 series contactor out
of one of larger singles. See:
http://www.aeroelectric.com/Mfgr_Data/Contactors/Eaton_CH/6041SeriesPowerRelays.pdf
Needs to be a 28v, 200A or larger device. Alternatively,
you can use an el-cheeso White-Rogers device. See:
http://www.aeroelectric.com/Mfgr_Data/Contactors/Stancor-WhiteRogers/Stancor_70-Series.pdf
You'll need a 70-903 or 70-907. You can get
these from Allied Electronics at:
http://tinyurl.com/2rnz43
also a fat diode on a heatsink to isolate the
power supply from the battery to avoid the
"crowbar" nuisance trip I cited earlier. See:
http://www.vishay.com/docs/93162/93162ird.pdf
Digikey has the IRD3911 in stock for about $9
at:
http://tinyurl.com/yoqsn7
Nice fat heatsinks for these diodes are getting
hard to find. Drop me your address and I'll
mail you one.
You'll also need a hardware store toggle switch,
an ANL200 current limiter (don't leave this out!)
and a nice, bright red PWR ON light for the cart
to show when the output leads are hot. It would
also be nice to have a voltmeter. I can fix you
up with one.
In operation, the battery cannot be connected
to the airplane unless the HP supply is plugged
in and turned on. The diode prevents backfeed that
WILL damage your power supply. By the way, if you
want to use the full output capability of HP supply,
you'll need to wire it for 240 volts and run a 240
line cord to it. I have one of these on my bench
and it will pop a 20A breaker when operating from
120 VAC and I try to load it to full output.
You'll find this cart quite handy. In fact, with
some minor additions, you could make it a 14/28
volt cart by connecting the batteries in parallel,
changing the contactor to a 14v device and use
a resistor in series for 28v operation. The indicator
light is a little dim on 14v but if you've got
a really obnoxious light for 28v service, it will
be adequate at 14v.
I had just such a cart and used it a lot. I
had 12v car batteries instead of RG but otherwise
it was the same setup. Of course it would crank
an engine very smartly. My cart had "piper"
style ground power plug on the end of the service
output cord. I then fabricated some adapters
to let me plug into a mil-std jack or attach
directly to the b-lead of an alternator to emulate
a running engine/alternator.
This may seem like a lot of fuss . . . but you'll
be glad you did it.
ignore this and see earlier post . . .
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
ebay right now at:
See AOL's
<http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004>top rated
recipes and
<http://body.aol.com/fitness/winter-exercise?NCID=aoltop00030000000003>easy
<http://www.matronics.com/contribution>http://www.matronics.com/contribution
<http://www.matronics.com/Navigator?AeroElectric-List>http://www.matronics.com/Navigator?AeroElectric-List
incoming mail is certified Virus Free.
Checked by AVG.
Posted: Mon Dec 17, 2007 7:20 pm Post subject: Battery Question? |
Good Evening Bob,
Wow!!
I had no idea it would take that much effort.
I do have a contactor that may work. It is a 6041H189 from a V35B.
I'll start gathering the rest of the needed materials. Thanks for all the information.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 12/16/2007 11:57:29 P.M. Central Standard Time, nuckolls.bob(at)cox.net writes:
| Quote: | Okay, you need to build up a "shop power
retasker(at)optonline.net Guest
Posted: Mon Dec 17, 2007 8:43 pm Post subject: Battery Question? |
Not to knock down Bob's suggestion, but I am not sure that you actually
need to go to quite that much trouble. It really depends on what you
want to do, how long you want your test batteries to last (both in the
sense of supplying power and in the sense of lifetime until they are
disposable). What Bob is suggesting would be great if you were to go
into the airplane avionics test and installation business.
You have to decide how sophisticated you want to get and how much
versatility and protection you need.
I suspect that what you need is a couple of batteries and a battery
charger. Use the batteries to do your testing and then connect them to
a charger overnight to be ready the next day. Alternately, just use
your 25A supply and forget the batteries. If you do need more than 25A
then you would need the batteries, but if not just keep it simple. The
HP supply is a good one and should do just fine up to it's maximum load.
My $0.02.
Do not archive.
Dick Tasker
Wow!!
the information.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
<http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004> and
for winter.
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Posted: Tue Dec 18, 2007 5:45 am Post subject: Battery Question? |
Wow!!
Shucks, that's usually the hard part
to find.
information.
It doesn't HAVE to be that much. For
the occasional ground power task, I've
resorted many times to simple work-arounds.
But if you want to use the HP supply
in conjunction with batteries, you're
well advised to accommodate the
crowbar ov protection. I smoked one
of my venerable HP supplies some years
ago discovering this problem.
But I think you'll find that when
you have a robustly packaged, convenient
tool it will get used much more
often than you anticipate now. The
mechanics at our little airport did
a lot of ship's battery testing on customer
aircraft where the bus voltage low
(no alternator) and added wear and
tear to the battery. After I built
the cart, it got used several times
a week.
Posted: Tue Dec 18, 2007 6:48 am Post subject: Battery Question? |
Thanks Bob,
I am gathering the material and will lean on you for wiring advice when all is in hand.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 12/18/2007 7:56:31 A.M. Central Standard Time, nuckolls.bob(at)cox.net writes:
| Quote: | But I think you'll find that when
a week.
