ddw55(at)hotmail.com Guest
Posted: Wed Dec 19, 2007 12:53 am Post subject: Throttle control to 3300 Jabiru in Esqual or Lighting (or a |
Clive,
I made a small block out of Ertalon of about 6 cm square to put some friction on the tube between the 2 throttle levers.
It is fixed on the tube of the central beam just behind the tube with the throttle levers
I can change the friction by tightening the nut on the bolt. Needs some tuning.
Works fine.
Danny
| Quote: | Subject: Throttle control to 3300 Jabiru in Esqual or Lighting (or anything else I suppose)
Date: Tue, 18 Dec 2007 21:46:16 +0000
To: lightning-list(at)matronics.com
Hi, I have finished the Esqual and currently have the stock throttle set up fitted.
That is elongated arm on the bing and a two lever set up that puts a lever on the left and right of the pilots seat with a tube beneath the seat pan that joins them up.
No amount of fettling seems to make its action acceptable for control.
I notice on the pictures most of you have fitted the plunger type throttle on Esquals and lightnings.
Is this just connected to an elongated arm on the bing carby as the Esqual original design?
Is a verier needed or is a standard ACS A800 friction type OK?
Some have dual throttles, do these connect to a drive rod? And then a single drive to the carb?
Are there any other installations that are used and recommended?
Is a vernier throttle OK to use for fine control?
Do all vernier throttles have the release buttons?
Thanks, Clive
" target=_blank>http://www.matronics.com/Navigator?Lightning-List
p://forums.matronics.com
| De snelle weg naar een praatje Windows Live Messenger
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
