pjdisher(at)bigpond.com Guest
Posted: Wed Dec 19, 2007 1:16 am Post subject: 2 pictures for you |
att. Clive James,
Peter Disher Here Clive, Attached 2 photos of what I've done, I think it will work quiet well as I'm not finished yet so, good luck.
Pete D
OZ
You have been sent 2 pictures.
These pictures were sent with Picasa, from Google.
Try it out here: http://picasa.google.com/
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
Clive J
Posted: Wed Dec 19, 2007 2:28 am Post subject: 2 pictures for you |
I like the look of that, many thanks.
I was trying to keep the Esqual standard as it was originally going to
be a demonstrator for the UK distributor. Now I'm all on my own.
Are all the arms all the same length? You if you make the input arms
longer than the out put you'll be able to get a longer stroke on the
throttle control for better control.
Thanks again, Regards, Clive
ddw55(at)hotmail.com Guest
Posted: Wed Dec 19, 2007 4:43 am Post subject: 2 pictures for you |
Indeed, longer control arme give you a finer control.
We have been taxiing fo 1,5 hrs and floqn 1 hrs but we didn't feel the need for a finer control.
Did you extend the lever on the carburator as indicated in the manual?
Danny
> Subject: RE: 2 pictures for you
[quote] Date: Wed, 19 Dec 2007 10:27:13 +0000
To: lightning-list(at)matronics.com
--> Lightning-List message posted by: "James, Clive R" <clive.james(at)uk.bp.com>
Posted: Wed Dec 19, 2007 1:10 pm Post subject: 2 pictures for you |
Yes Clive, I have made the arms all the same length of 125mm centre to
centre. This gives min.cord height movement of 8mm over 90mm of throttle
movement.
Have mounted the horizontal shaft 63mm off the firewall enabling me to have
90mm of throttle movement.
Mounted shaft in fiber blocks, on to 2*1*1/8 al angle, onto the flute tube
vertical channels.
Am using A-820 throttle control 05-09436 aircraftspruce.
Pete D
OZ
