klwerner(at)comcast.net Guest
Posted: Wed Dec 19, 2007 4:01 pm Post subject: good warning label |
Paul,
Being that straight forward would definitely defeat the purpose, now wouldn't it? It is not what you say, but how you say it: I would try "I need custom brake lines for an off road-RV" certainly wouldn't even be considered lying...
rmkeith(at)gwi.net Guest
Posted: Wed Dec 19, 2007 5:24 pm Post subject: good warning label |
Tell them it's for a snow blower.
jfogarty(at)tds.net Guest
Posted: Thu Dec 20, 2007 8:35 am Post subject: good warning label |
Don,
How about the fittings are they standard AN4 fittings that would be compatible to our fittings? You have the hoses in your shop, do they fit okay on the brake fittings? Do you think it would be a good place to order our brake hoses through and how was their service and turn around time?
Do you have a link to the shop you are working with?
Jim
RV9 Builder
mike109g6(at)insideconnec Guest
Posted: Thu Dec 20, 2007 8:53 pm Post subject: good warning label |
Jim,
To make your own brake hoses is really no big deal. ANY fitting that says 'AN' is an acceptable fitting. 'AN' is a standardized mil-spec terminology= ArmyNavy. Any auto shop can make you brake lines. As mentioned - you must use 45 degree flaring tools -not automotive 37 degree. If it is 'AN' fitting, it is 45 degree. Go to www.summitracing.com or www.jegs.com and they have pages upon pages of fittings and different types of hoses. It took me about 2 hours to make mine. The hardest part is figuring out the length that you need. Steel braided Stratoflex hose is by far the superior type of hose. You can find Aeroquip fittings at those two sites as well. I prefer Russell. Same fittings, less $. Of course you only have to worry about flaring with hard lines-not hoses. And to answer your next question-yes, they have fittings that are combinations AN/NPT to fit your parking brake or reservoir.
Hope that this helped,
Mike H 9A/8A
Vanremog(at)aol.com Guest
Posted: Thu Dec 20, 2007 9:31 pm Post subject: good warning label |
In a message dated 12/20/2007 8:55:53 P.M. Pacific Standard Time, mike109g6(at)insideconnect.net writes:
| Quote: | | As mentioned - you must use 45 degree flaring tools -not automotive 37 degree. If it is 'AN' fitting, it is 45 degree. |
Actually he's got it exactly backwards, so please don't believe this information.
Standard brass fittings at the hardware store and most other similar commercial fittings are 45 degree and aircraft (AN) is 37 degrees. Do not mix up the applications or the tooling. Many of the new racing applications have adopted the aircraft standard.
-GV
See AOL's top rated recipes and easy ways to stay in shape for winter.
pbesing(at)yahoo.com Guest
Posted: Fri Dec 21, 2007 2:33 am Post subject: good warning label |
AN Fittings are 37 degrees.
Paul Besing
jhstarn(at)verizon.net Guest
Posted: Fri Dec 21, 2007 7:52 am Post subject: good warning label |
Sorry to disagree BUT "AN" fittings are 37 degree NOT 45. Go to the www.jegs.com sited below and read what it says about the 37 degree flairing tool Jegs# 80084. 45 degree flare is used in plumbing, heating & A/C lines. Hot rod & racing use 37 degree because of aviation fitting availabilty.
KABONG
(C-20, C-36 Calif Contractor for A/C & Plumbing and HRII builder and EAA Tech Advisor and one time Corvette racer)
| Quote: | From: mike humphrey <mike109g6(at)insideconnect.net>
Date: 2007/12/20 Thu PM 10:51:45 CST
To: rv-list(at)matronics.com
Subject: Re: good warning label
| Quote: | Jim,To make your own brake hoses is really no big deal. ANY fitting that says 'AN' is an acceptable fitting. 'AN' is a standardized mil-spec terminology= ArmyNavy. Any auto shop can make you brake lines. As mentioned - you must use 45 degree flaring tools -not automotive 37 degree. If it is 'AN' fitting, it is 45 degree. Go to www.summitracing.com or www.jegs.com
Posted: Fri Dec 21, 2007 8:22 am Post subject: good warning label |
Mea Coupa - I got it backwards. You are correct. Thanks for the correction.
Mike H
Carl
Posted: Fri Dec 21, 2007 3:14 pm Post subject: good warning label |
Also, AN is now Air Force-Navy standards, some bureaucrat changed it a
while back. I'm from the government and I'm here to help. EEEE gads. CJ
_________________ Carl Bell
Building N947CB
RV 7A |
Posted: Fri Dec 21, 2007 7:12 pm Post subject: good warning label |
In a message dated 12/21/2007 3:16:01 P.M. Pacific Standard Time, carlbell(at)gforcecable.com writes:
| Quote: | Also, AN is now Air Force-Navy standards, some bureaucrat changed it a
while back. I'm from the government and I'm here to help. EEEE gads. CJ |
Was that when they put "under god" in the pledge? ;o) EEEE gads squared!
Merry Christmas everyone!!!
N1GV the soaring heathen (RV-6A, Flying 872hrs, O-360-A1A, C/S, Silicon Valley)
